Question about Dryers
My becko dryer keeps saying water tank full when it's empty. Also the water is not going into the tray?
SOURCE: Tank full light stays lit.
Under the water bottle is a drain hole,when the bottle overflows water runs down this hole through a pipe to a reservoir behind the condensor unit, there is a float in this reservoir that rises and clicks a switch that activates the full tank light and stops the machine working,
removing the stopper at the rear and emptying the reservior should do the trick,If the float does not go back down due to dirt in the machine the left hand side panel can be removed by taking off the top then the retaining screws,one inside at the top the rest in the back panel,remove the one screw holding the float switch unit and clean the black float.(Make sure it's not plugged in)
Posted on Jan 21, 2008
Timon90
  • 126 Answers
SOURCE: Zanussi Tumble Dryer
Sounds like the condense pump is bad. Replace it, or look if there is lint in it. ;)
Posted on Jan 25, 2008
  • 135 Answers
SOURCE: water full light wont go out
Make sure the water dispensor is pushed back firmly as there is a switch that is operated by the dispensor. If this fails the switch may be faulty.
Post back if further assistance needed.
Thankyou for using fixya.
Posted on Nov 29, 2008
SOURCE: Hoover 381/1 condenser tumble dryer empty water
Got a similar problem with an HNC172. The supplier said it is the water indicator sensor that is not working. He fixed it! It still stops!!! Clear lint from the trap in the door. Empty what little water there is in the tank, then make sure it has a good shove to get it back into place and the tube/catch is well joined back. Also take out the condenser unit above water tank, stick in the bath and put the shower hose through it to clear lint. Recommend getting a tea strainer over the plug hole or you block your drain as quite a bit comes out. It helped for a while, but it still has problems. Might be the thermostat for the heater? check the error codes. They flash a different number of times within 15 seconds to indicate which problem is happening.
Posted on Jan 09, 2010
SOURCE: Hoover condenser dryer VHC180. Water empty
hoover dryer water leaks when machine is running.
Posted on Jan 26, 2010
Beko dryer
i have had this problem and its usually the pc board is faulty
Mar 28, 2014 | Dryers
My beko dryer keeps saying water tank full when it is empty!
empty the small reservoir around the back
there's a single screw to take out and siphon the water out with a small bore pipe I used two drinking straws taped together
you will see the float go down and turn the switch off
Mar 21, 2012 | Dryers
We have a pacw160a pinguino and the water tank has not emptied and is full but the display says the tank is empty?? can you help thanks
I've just been given one of these units & it had the same problem. Turned out to be a lack of decal procedure. Even though we live in a very low calcium area (Sydney, Australia), the corrosion of the copper coils seems to cause it.
The small pipe taking water into the tray beneath the coils was completely blocked & there was a ton of debris in the tray. With the pipe blocked, the water never runs into the tray to lift a little float which triggers a reed relay. The system therefore thinks there is no water in the tank.
I cleared the pipe, flushed out the tray, decal'ed it & all is now fine. If you're not up to this (& it was fiddly!) a simple decal may work, but it's not likely as the decal fluid will probably not make it as far as the blockage!
John
Nov 30, 2010 | Heating & Cooling
On our Seaco Professional the water tank is full but says empty
On the corner of the water is there a black rectangular float, if yes then the water sensor is probably not connected.
Mar 27, 2009 | Saeco Royal Professional Espresso Machine
Zanussi condenser drier: tank full light on even though empty
its either going to be fluff in the float which you can get at by taken the side panel off .or its fluff in the valve behind the water tank
Jan 11, 2009 | Zanussi TC7114W Electric Dryer
Descaling?
With the selector buttons find Descaling and press OK
This process takes about 35 minutes
1. Empty the water tank, drip tray and grounds container.
2. Insert tray and grounds container, refill tank with with 0.5 Lt. of water and add descaling agent (not the pill or powder used for clean cycle) to tank. Make sure its completely dissolved.
3. Place a container or cup under the steam wand large enough to hold 0.5 lt.
Display says Descaling and press OK
4. Press the water button
Display says Descaling in Progress
after the descaling agent is exhausted
Display says Empty Drip Tray and Spent Grounds
5 Also remove rinse and refill the water tank to Max line
6. Press the water button again
after the machine stops
7. Empty the drip tray and spent. ground container and replace
Display says Rinse Press OK
Display says Appliance Ready
In essence go to Descaling Press OK and follow the directions as they are displayed.
Sep 07, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Descale
Aug 02, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Hotpoint dryer TDC32
check the switch where you remove the tank towards he bottom
Dec 30, 2007 | Hotpoint TDC32 Electric Dryer
Dec 30, 2007 | Dryers
Dryers Logo
Top Dryers Experts
