Question about Samsung RB195ACBP
Freezer working but fan not running to cool fridge
dididsaythat
  • 291 Answers
SOURCE: SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Posted on Oct 12, 2007
SOURCE: samsung rs21dcns fridge freezer Ice
Found an electrical drawing and resolved the issue - Broken cable
Posted on Nov 11, 2008
  • 115 Answers
SOURCE: fridge and freezer not staying cold but lights and fan working
the problem is going to more then likely in the main control board which is on the back of the refrigerator in a little compartment this board is bad about going out if you have power surges or outages
Posted on Jan 03, 2009
notsomot
  • 67 Answers
SOURCE: freezer and fridge don't cool at all. everything else works fine
Heya,
There is a fault with samsung fridges that when it goes on defrost it will not start the compressor or the fans again. If you turn on the power the fridge should run for a couple of hours and then stop if so you will need to get a tech out to order a samsung yellow sensor and a fridge defrost isolation sensor. If the fridge does not work at all if you would like i will talk you a couple of little checks before calling someone out.
Hope this helps
Posted on Jan 08, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Fridge side not cool and freezer side cooling like a fridge
Most likely a defrost problem. Are you sure your model is the model posted above your post? RS2630SH If not please let me know the correct model number. I have most of the manuals on the Samsung..............Sea Breeze
Posted on Jun 20, 2009
My kenmore 253 upright freezer/fridge is not cooling the fridge part correctly. It's cool but not cool enough to keep the food fresh. The freezer works well sometimes. And sometimes it seems that it's not...
Try this test. Set a window fan behind the fridge to constantly blow air across the lower coils at the floor. If the fridge works well after a while of this, then the lower fan on the fridge needs replaced. Sometimes though, after a while, the fan will finally start working again because the cycle has finally corrected itself with the test. Leave the window fan run on low for a few days before removing it. The hum you hear is the compressor moving the coolant and is supposed to do the hum sound. That's good. Now once the fridge is working, and you still have a good freezer section and not cool enough below in the fridge for you, there is a knob that sets the cool lower by opening flaps under the freezer to let more cold down to the fridge area. Set this knob to colder and the flaps will open more.
Nov 11, 2014 | Refrigerators
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
Kenmore side by side fridge. Green temp light flashing for fridge side, freezer side working fine. Fridge side not cooling.
possibly frosted up at the air door between the fridge and freezer, or the fan in the freezer is not pushing cold air into the fridge side, if you can not hear a fan running in the freezer when the fridge is running (compressor on) then change out the fan
Jul 18, 2011 | Kenmore Side by Side Refrigerator
Freezer works fridge does not
Needs to be completely thawed for 2 days. Or wlse the circulator fan under the freezer panel inside freezer is not working. Take the plastic bottom of freezer out and let thaw. Then plug in fridge and check if the fan is running inside there. Do not poke around inside there or fridge will be punctured and ruined.
Jan 28, 2011 | Roper RT14DKX Top Freezer Refrigerator
My refrigerator stopped cooling.But my frezzer still works.
check the fan that runs between the freezer and fridge section [usual access is from the freezer side] if fan not working check thermostat is set at coldest in fridge then check for power to fan if power check for blockage from ice, food.etc if clear check damper inside housing is open and working properly---the fridge is cooled down from the freezer via the fan
Jul 26, 2010 | Frigidaire Refrigerators
Fan is not working and fridge is not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
ARHGADF
Jun 03, 2009 | Amana ARB2557CSR / ARB2557CSL Bottom...
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Brand new refrigerator not cooling
ok what he was trying to say is that the freezer does all the cooling for both sides as nothing in the fride side cools and in order for the fridge to reach its proper temp the freezer should run any where between -0 to-10 then the fan in the freezer draw-es air from the fridge and cools it and circulates to the fridge now i need to know a few things is the compressor running is the freezer fan running do you see any frost on the back wall of the freezer section is the fan running in the back that's near the compressor to cool the condenser coils then i can better advise pleas hold my rating till we are done where did you purchase the unit
Jul 22, 2008 | LG LRTBC1825T Top Freezer Refrigerator
Samsung RB195ACBP Logo
63 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
