Question about GE Energy Star 3.7 IEC Cu. Ft. Front Load Washer with Stainless Steel Basket
Bad bearing on a GE Adora front load washer
Model number is partially faded and can't read it
SOURCE: GE ADORA model WHDVH626FWW
you have to clean out the filter on the bottom by removing the lower panel and twisting the cap... careful lots of water comes out but will work great after
Posted on Dec 13, 2007
  • 3 Answers
SOURCE: Ge Adora Front Loader
If you have not already done so, clean the filter behind the panel in the front bottom of the washer. Remove the three philips head screws to get the panel off. Unscrew the plastic filter on the right hand side (use a shallow cake pan to catch any water). Remove the filter and clean out the pens, pencils, change, lint, etc... and put back in. All should work well after this. Thanks, Greg
Posted on Jan 03, 2008
dutchman05
  • 487 Answers
SOURCE: GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Posted on Apr 23, 2008
  • 15 Answers
SOURCE: how do you replace drum bearings on a GE front
you can not. must replace entire rear of two piece drum that holds bearing. might not be worth time and costs!
Posted on Sep 29, 2010
Testimonial: "Thank you the info was very helpful."
  • 87 Answers
SOURCE: has anyone determined what the
Maybe contacr GE, u idiot
Posted on Oct 14, 2010
GE adora front load makes loud rattling sound in spin cycle. nothing in drum. sounds like a ball bearing
its the inner baskets bearings behind this basket as water gets past the rear seal into these bearings and ruins them,you need to dismantle the entire unit to remove the inner basket from the outer tub to replace these bearings
Oct 27, 2012 | GE WSXH208A Front Load Washer
Ge adora WHDVH626FWW makes clunking noises when spinning, bearings seem ok
Could be a broken Hub Spoke, My Kenmore broke at the spokesand bearing e.of drum,
Sears replaced all parts as the were still uder warrenty. Less than 10 years old, would have been over $1,000 cost otherwis.
Sep 30, 2012 | GE Wh12x10309 Heater for Adora Front Load...
GE Adora front load washer turns until water is added then won't turn or spin
You should contact GE or qualified appliance repair center to be looked at professionally.
May 06, 2012 | GE Wh12x10309 Heater for Adora Front Load...
Got a decimal point in the minutes and is not starting and is counting in sec not mins front loading washer ge adora 4-5 yrs old
What is the model number that is posted on the machine? On the model number that is posted above I do not see in the database that it has a LED display readout.
Feb 08, 2011 | GE WSXH208A Front Load Washer
I think I need to reset my front loader (adora GE) How do I do that?
Unplug unit, Plug back in.Rotate control knob to correct Model number.Press and hold start key till beep is heard,press power key to reset
Oct 22, 2009 | GE WSXH208A Front Load Washer
Ge front load washer model WSXH208A Will not spin
Mine kept stopping mid cycle also, pouring water on the floor, then the start/pause button flashed and the door unlocked. I found the solution to clean the lint filter on the GE Adora. Go to http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
I just did this and my washer is now running instead of the flashing start/pause and door unlocking. It was fairly easy. Make sure you have towels and a flat pan to catch the water if you don't have the machine on a riser. There may be water inside so a wet vac may be helpful too. Once my washer finishes what was in it, I have these funky towels to clean. You'll be very surprised what you find in the filter! Best of luck!
Oct 13, 2008 | GE WSXH208A Front Load Washer
Washer won't drain
Had the same problem, this fixed it!
Aug 05, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE Energy Star 3.7 IEC Cu. Ft. Front Load Washer with Stainless Steel Basket Logo
18 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
