Question about Elgin Watches
Elgin watch battery
I have an Elgin VD337 005 D275A analogue sport watch that takes a CR2016 and a 377 battery. Where is the 377 battery located?
The 377 battery is located behind the CR2016 battery. You will have to completely remove the motherboard to change out this battery that runs the analog portion of the watch.
Posted on May 05, 2014
5 Suggested Answers
escapement
  • 2334 Answers
SOURCE: opening an elgin pocket watch
The best tool to do it is watchmakers knife, but any proper knife with hardened steel blade can do the job. Make sure the blade is NOT flexible.
Check carefully the sides of your watch and you will notice the groove. Place knife blade into that groove and press it in. At the same time try to make a scooping turn to lift the caseback. Usually there must be underlayed caseback as well and it opens exactly in the same manner.
Make sure you do all this carefully and do not let the blade to slip or your watch will end up with nasty scratches or even damaged movement.
That job isn't a big deal, but requires some skill, so, BE CAREFULL.
Don't forget to rate, please.
Posted on Jan 05, 2009
  • 8404 Answers
SOURCE: how do you open the back of an antique Elgin pocket watch
You might be able to pop it open with a pocket knife ... don't stab yourself though.
Posted on Mar 08, 2010
SOURCE: need instruction manuel for elgin fg010-007 sports
The movement in this Elgin is made by Citizen. After you change the battery, you need to reset the hands so that the watch functions properly. Select chronograph function with lower-right button. Then pull-out the same button. Push the upper left button to select the UTC, hour, and minute hands. Then use lower-left and upper-right buttons to make sure everything is aligned to 12:00 position. After setting the hands to 12:00, push in lower right button. Now you can set the time by selecting the SET using the lower right button. Pull out the same button and choose your time zone to set.
Posted on May 13, 2010
  • 2501 Answers
SOURCE: Instruction manual which came with Umbro junior
Go to http://www.nike.com/timing/ and select your watch range from the drop down menu that is revealed when you click on "find a manual for your model"
Posted on Mar 12, 2011
How to turn-off chime of elgin Westminster chime wall clock with pendulum?
Are there two batteries. One for the time and one for the chime? Try taking the one for the chime out and it should stop chiming. mine worked that way but is a different make.
Feb 04, 2017 | Elgin Watches
Heeeeeeeeyy!! Can anyone please tell me what battery I should use for a Seiko Quartz Sports 100 7123-8230 watch??? Thankyou!!!!!!
If your watch is an analogue, then yes, it is very safe to assume it is 1.5V.
If your watch is digital, depending on how many functions it has(especially if it has a night light), it will most probably take 3V.
In either case, it doesn't hurt to start testing with a 1.5V battery.
google.com/+GopakumarGopalan
Aug 06, 2015 | Seiko Watches
Setting analog part of analog/digital cardinal watch
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs.
Oct 23, 2012 | JCPenney Casio Casual Sport Analog/Digital...
Change battery in Elgin watch FQ024-007
The back of this watch doesn't pry off, it screws off.
I used the open tip of a needle-nose pliers to unscrew the back of the watch by inserting the the tips into opposing grooves in the back of the watch and turning it counter-clockwise.
Once the back of the watch is off, there are a few slotted screws that appear to hold a metal cover over the back of the watch 'guts', you'll need a jeweler's screwdriver to remove these screws (I counted 3 of them).
The battery is right under this cover.
When re-assembling the watch, I would apply a thin coat of sewing machine oil, or some other non-reactive lubricant, to the black gasket seal which should be on the back cover of the watch.
Jul 10, 2012 | Elgin Watches
Setting chimes and time for elgin e77
I thought I had some instructions on that Elgin clock, but it was for a mechanical wind up unit. There were many different models of these programmable clocks manufactured and the instructions differed. And they are just not readily available. I received a sports watch in a trade (with no instructions)and after 3 months I am still trying to determine how to program it!
It might be that the "H" stands for hours and the "S" for set. So how do we set the minutes? I will pose this question to my Internet Clocksmiths Group and see if anyone knows. If I do receive some instructions, I will get back with you.
Buy Performance Parts.
Jun 04, 2012 | Elgin Watches
Need to add links to a new Elgin watch band. The number on back of watch is SR626sw
That's the battery number for the watch also known as the #377. It's the most common watch battery in the world. Your model number is located at the bottom of the dial (face) below the six-o'clock position. You will need a 10 power jeweler's loupe or magnifying glass to see it and read it. Jot down the number and contact Elgin directly (MZ Berger Co,) for the extra links.
MZ Berger.
Jun 20, 2011 | Watches
I own an Elgin man's wrist watch with quartz movement. It has the N, S, E, & W, on the cover together with" 30 NE 60, 120 SE 150, 210 SW 240 & 300 NW 330. It's water proof to 30 meters. Stainless...
I think it maybe the same watch that i had purchased years ago. I have an Elgin D275A Wrist Organizer Calender World Time Telememo Scheduler Ana-Digit and yes i do have the manual and i have a scanned copy of it i can send you. It's an impossible watch to find now. you can email me @ jdonohew@yahoo.com
Apr 01, 2010 | Bulova Watch
How do you open the back of an antique Elgin pocket watch
Mar 08, 2010 | Elgin Circa 1904 Watch
I JUST PURCHASED A NEW ELGIN LADIES WATCH ONLINE AND IT NOT WORKING. WHAT DO I DO?
If you are able to, send it back where you got it, most companuies have 30day return policies...if its been longer take it to a reputable jeweler or watchmaker and have the battery replaced...sometimes watches have been sitting in a warehouse for awhile before they are sold and the batteries have run down.
Nov 09, 2009 | Elgin Watches
Need instruction manuel for elgin fg010-007 sports watch
Feb 28, 2009 | Elgin Watches
Watches Logo
638 people viewed this question
Top Elgin Watches Experts
jdthefixer
terry stevens
Are you an Elgin Watch Expert? Answer questions, earn points and help others
