Motorolla 630 pvr stops working and I get no picture or sound
I have 3 hdmi and I want to know if there is any output so I can hook my surround sound to my tv
HDMI sockets on a TV are normally for input only. If you can post the make and model of the TV we may be able to tell you if it has sound output, but that was not commonplace until the most recent HDTVs.
If it does not and you have a TV signal set-top box of some type or PVR, that will almost sertainly have some sort of sound output on it, like this
http://geoffthegreygeek.com/wp-content/uploads/PVR-Component-video-connection.png
So the idea is to connect the picture to the TV with the normal aerial cable from the STB or PVR, then the audio to your sound system aux input with the 'red and white audio' connections.
Note you will probably not be able to have the sound system and TV speakers on at the same time as you might get a weird echo effect.
Apr 02, 2016 | Audio Players & Recorders
I have checked cables and different methods of connecting, but the white and red audio out of my PVR appear to have stopped putting out sound.
Go through the setup of the PVR and check the sound settings. It sounds like it's only producing digital audio, that's why it works with HDMI but you want analog, so set the audio to stereo, or try every setting to see what works!
Jan 19, 2015 | Televison & Video
Why does my pvr keep freezing
Sorry can't help on this. Presumably you've switched off/on at mains and checked all connections secure. Would a factory reset help, see tips how to do on fixya, although not sure if you would lose library data.
Aug 19, 2014 | Bush BTU500DTR 500GB Twin Tuner Freeview...
My volume don't work
I too have the same problem but have misplaced the original converter. If you have one, try using that for volume. Even the volume button on TV will not work. Looks like your cable connection is ok. Anything else connected to this tv like PVR, ?
Jul 19, 2013 | Sanyo DS19310 19" TV
How to clean fan laptop for hp 630
I have a problem for few days with my hp 630.
Cooler speed was increased and does not stop. what to do? be opened and cleaned? You can see a picture here.
Aug 03, 2012 | Computers & Internet
For the last 2 weeks our PVR has worked fine only about half the time. It will suddenly cut out: picture and sound disappear and the pushing the MENU button the produces zip: no signal strength screen or...
Sounds faulty to me (especially if it has been working fine for the last few years), i'd get it replaced, some of the new TiVo boxes are insanely good, and well worth checking out despite their also insane prices.
Thanks,
Moza805
Aug 30, 2011 | Televison & Video
TomTom Go 630 malfunction
re install/repair the software
May 04, 2009 | Tomtom Go 630 GPS Receiver
Question regarding audio connections Akai 30" LCD TV
a switch box is needed the s video shares the red/white audio with the yellow rca that is being used already
May 07, 2008 | Televison & Video
Flat screen television picture freezes but not sound
Source box problem......nothing wrong with TV............T.
Feb 26, 2008 | RCA 32F531T 32" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
