Question about Swan SR5130 Freezer
Red light came on my swan upright freezer - Swan SR5130 Freezer
I HAVE A SWAN SR4150W CHEST FREEZER A ND I HAVE JUST PUT IT ON AFTER A YEAR THE RED ALARM LIGHT IS ON IS THIS JUST UNTIL IT REACHES THE RIGHT TEMPETURE
Most freezers have a red neon light on the door to indicate if there is a loss of power, so that you can mitigate food loss before you call a service co.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 20, 2017 | Swan Freezers
Having restarted my upright Freezer how long will it take for the flashing red light to stop flashing
what was the reason for the trouble code --if problem not fixed trouble light will keep flashing if light flashing due to temp when setting is reached will stop
Jul 17, 2016 | AEG 10.35 cu. ft. / 293 liter Upright...
Frigidaire upright freezer
Hello Susan, thank you for your post!
Did your freezer previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your appliance by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on your freezer. After deactivating the alarm and your freezer has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Dec 07, 2013 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire freezer ffu14f5hwg red light on
It isn't reaching temperature. The red light comes on at -12c Check the condenser is clean, thermostat set ok and compressor humming nicely
May 22, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
I am looking for the instruction manual to my lost freezer SWAN SR5030
If you lost the freezer, why do you need the manual?
Swan is a UK company that does not have a website for their freezers. The UK help center phone number for Swan is: SWAN helpline: 0845 610 4118
email: sales@swan-brand.co.uk
Also, isn't a freezer a little large and hard to loose?
Feb 01, 2011 | Freezers
Defroster get red hot
Kenmore Frostless Upright freezer model# 23971. The alarm sounded, all contents in freezer is frozen solid. We turned the alarm off, but the red light continues to blink. How do you reset the alarm and stop the red light from flashing? It has been 3 days now and every time we have check to see if the contents has started to defrost, there is no signs of defrosting, everything inside of the freezer remains frozen solid.
Sep 01, 2010 | Kenmore Freezer 20.6 cu. ft. Manual...
Upright Frigidaire Freezer
The Amber light is the Power 'On' indicator. The Red light is a Temperature Alarm indicator. THe Red light comes on if the freezer compartment rises above 20 degrees F (for example a freezer malfunction or someone left the door open). You also probably have a rocker switch (or two holes that are over a rocker switch) that is in between these two indicators. If you do, that's an audible (loud buzzer) alarm when the red light comes on. The rocker switch is a simple on-off switch to silence the alarm or turn it back on.
Jul 07, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Swan SR5130 Freezer Logo
76 people viewed this question
Top Swan Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Swan Freezer Expert? Answer questions, earn points and help others
