Question about Lutron CTCL-153P-WH - CFL & LED Dimmer, Slide/Rocker, 120V, 600W
Ctcl-153p will not dim lights - Lutron CTCL-153P-WH - CFL & LED Dimmer, Slide/Rocker, 120V, 600W
The dashboard illumination is dim and won't go bright also the Foglights will not turn on and also the stereo is dim. Changed the light switch but still the same
is it adjusted by the light switch left on bright right dim all when lights are on all dash lights will dim thats normal
Apr 19, 2016 | 2008 Volvo XC90
The light is dim with the door open or closed running.whats wrong?
Lights lowering in the kitchen when turning on microwave ...
diy.stackexchange.com/.../lights-lowering-in-the-kitchen-when-turning-o...
Nov 4, 2012 - Lights lowering in the kitchen when turning on microwave oven: symptom of an ... In the best case, this may be normal if the dimming is minor.
Possible causes of dim Microwave Oven display ' All About Circuits
forum.allaboutcircuits.com > ... > Electronics > General Electronics Chat
Jun 13, 2013 - I've seen some Microwave ovens that will not display a backlight anymore. They still work, but the display is so dim, you have to be inches away to. ...Monitoring the output of a light-dependent resistor, or photoresistor, allows ...
What Is Causing My House Lights To Dim?
blog.1000bulbs.com/what-is-causing-my-house-lights-to-dim/
Dec 21, 2015 | Microwave Ovens
Light is dim
Why do my lights in my house dim when I use the Microwave or dryer ...
https://answers.yahoo.com/question/index?qid...
Jan 16, 2010 - I dont run a lot electricity. It seems that if I run something like themicrowave any lights that are on dim. Is something wrong here? I dont see why ... Light on microwave too dim to read -- can it be fixed? ' Yahoo ...
May 11, 2014
My lights dim when I turn on a powerful electrical device ...
Dec 31, 2007
Why causes all the lights to dim and then brighten repeatedly ...
Dec 28, 2006
More results from answers.yahoo.com
Dimming Microwave Light - Breville Support
brevilleusasupport.com/bmo734xl/dimming-microwave-light/
Apr 10, 2014 - Occasionally, when using power settings that are lower then the normal 100% cooking power, the light inside the microwave cavity may dim.
The indicator light on my FFAA52P fridge freezer has gone dim any answers
I have had a similar problem my light is very dim after contacting manufacturer I was told if the fridge freezer is still working fine then just put up with the dim light.
Feb 04, 2015 | Refrigerators
Gmc envoy bright lights work dim lights will not work
Your circuit lights may be bright or dim according to how your electrical system was set up. It may dim when lights are off and get bright when lights are on. ------------------------------------------------------------------------------------------
Car Diagnostic Tools
Nov 24, 2012 | Buick LaCrosse Cars & Trucks
Brake lights work but are very dim
It can be loose wiring or issue with bulb or the battery is weak or brake light socket getting short somewhere.Car lights getting dim,there are many such common issues noticed.I will share some familiar help links,related to your problem.
Click the link below:---2004 Dodge Ram: High Beam Light is DIM? http://technoanswers.blogspot.in/2012/04/2004-dodge-ram-high-beam-light-is-dim.html
----------Ford Odometer Dims intermittently http://schematicsdiagram.blogspot.in/2012/07/ford-odometer-dims-intermittently.html
---------Turn Signals Don't Work When Brakes Are Applied? http://schematicsdiagram.blogspot.in/2012/04/2005-gmc-envoy-turn-signals-dont-work.html
Brake light Switch Location? http://schematicsdiagram.blogspot.in/2012/04/1996-buick-regal-gran-sport-brake-light.html
----------- No brake lights on Buick? http://schematicsdiagram.blogspot.in/2012/04/no-brake-lights-on-buick.html
----------- Brake lights not working on 1989 BUICK REGAL? http://schematicsdiagram.blogspot.in/2012/04/brake-lights-not-working-on-1989-buick.html
These will help.
Thanks.
Nov 06, 2012 | 1999 Ford Contour
Bios password reset
when your installed the o.system the system indicated you what name you will in the computer. Remember ?
You must introduce.Otherwise you must press the key f2 and disable the password in the set-up
God bless you
Sep 25, 2012 | Dell Studio 1536 (S1536-153P) PC Notebook
Three flashing lights on dell studio
it happen when power problem comes check power adaptor and battery both
May 18, 2012 | Dell Studio 1536 (S1536-153P) PC Notebook
The lights on the dimmer flash and/or brighten and dim on their own. How do we fix this?
For 100% certainty, I would call Lutron's tech support at 1-800-523-9466. They're available 24/7 and can probably troubleshoot it more effectively than through this text-based dialogue. However...
I have three guesses...
1) Check the minimum load. The minimum load for those products is about 40-Watts. If there isn't enough lamp wattage pulling electricity through the dimmer, the dimmer may not have enough juice to keep itself powered up... and then shut down (hence any flashing you may see). If the issue only happens when the lights are at full (or close to full) brightness, then that's most likley your issue. To solve, either increase the lamp wattage, or replace with a dimmer that contains a neutral wire such as the MAELV-600M.
2) Check the load type. The dimmer's are rated for incandescent & halogen. If these are LED or CFL lamps, you are going t see issues. For dimming performance, either convert the lamps to incandescent / halogen, or investigate their new Diva dimmer for CFLs & LEDs: DVCL-153P-
3) If neither of those solve the problem, the next guess is to check the wiring. I wouldn't expect this to cause any "flashing" but in the wiring circuit, each device had a blue screw attached to it, and you need to make sure that the blue screws are wired/connected to each other and ONLY to each other - otherwise "automatic" dimming can take place.
But again, the only way to be certain is to use their tech support. I highly encourage you to use that.
Nov 07, 2010 | Maestro Lutron MAW-603-RH 3-way 600 Watt...
Open Questions:
Lutron CTCL-153P-WH - CFL & LED Dimmer, Slide/Rocker, 120V, 600W Logo
59 people viewed this question
Top Lutron Electrical Supplies Experts
Steve
jdthefixer
Craig Butler
Craig Butler
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
