Question about Canon Pixma MG5220 InkJet Printer
Canon mg5422 won't pick up paper
I have loade the paper tray about ten times and pushed "OK," but the paper isn't feeding into the printer. There are roller tracks on the paper but it isn't picking up.
3 Suggested Answers
SOURCE: Cassette error
On the control panel for the printer, there's a Feed Switch button that's easily touched by accident. Ensure the Feed Switch is set to the paper source you're using (e.g. either the back or front). The graphic of the printer next to the Feed Switch button will light up to indicate the paper tray it's attempting to use.
Posted on Nov 10, 2010
jurko170
  • 12 Answers
SOURCE: Canon ImageClass MF6550 Won't Pick up Paper or Feed Thur in Multipurpose Tray
Clean the pick up roller
Posted on Jul 30, 2012
How to load photo paper in paper tray canon mg5220
For front or front tray loading printers, shiny side down... for rear/back loading printers.., shiny side up. Pictures should be visible coming out of the exit slot. Using pre-cut photo paper requires some technique, if the paper holder does not have an adjustable paper width feature. Feed paper in one sheet at a time to prevent jambs.
Aug 27, 2012 | Canon Pixma MG5220 InkJet Printer
Doesnt print faxes or copies because the paper isnt picked up from the tray
1. Remove any paper from the Auto Sheet Feeder and Cassette.
2. Select the paper source with [Feed Switch].
3. Press [Menu] repeatedly until 3.MAINTENANCE> appears.
4. Use [<] or [>] to select <ROLLER CLEANING>.
5. Press [OK].
6. When cleaning has finished, repeat steps 3 to 5 for a total of three times.
7. Load A4- or letter-size plain paper in the selected paper source and repeat steps 3 to 5 additional three times.
Oct 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Wont grip paper on feed, keeps 'saying' paperjam
I have had this problem after printing a large batch of sheets on a heavy matte photo paper. The roller picks up a 'polish' from the surface coating and then fails to grip. I have tried cleaning the roller, with some sucess, but the best solution I have found is to feed through several blank sheets (just page throws in a Word document) of a ordinary 80 gram paper. Doing this between smaller batches of the photo printing seems to keep things flowing.
Jun 24, 2009 | HP Photosmart 2575 All-In-One InkJet...
Mp780 - Paper attempts to feed and fails Message: Load paper
Your paper feed source is wrong .Go to the printers control panel and change the feed source.
If all you do is 8.5X11 you can go into the maintenance tab and choose it to automatically change paper trays by selectin auto continuous feed.Make sure paper is in both trays of the same type and size.You will hear the printer try and grab the paper three times then it will automatically switch to the next tray.
Jun 10, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I have a canon image class d680. the machine no
Have you tried to clean the pick up rollers with a rag with a small amout of WD-40 or Simple Green. Clean the roller then whip off with a dry rag. If the problem improves you need to replace the pick up rollers. If not you may have to replace the paper feed clutch. Also, look to see if the seperation pad is ingaging when the paper tray is pushed in. Open the left side door. I've seen the actuator break. Also, have you tried to use the manual feed tray???? I know you made sure the paper guides in the paper tray are set correctly for the size paper in the tray??? Good Luck
Feb 26, 2009 | Canon Office Equipment & Supplies
Cassette error
Dec 15, 2008 | Canon Pixma MP500 All-In-One InkJet...
Paper feed
Fixing paper feed problems
  • Ifthe printer is not picking up paper, check to see if there is paper inthe IN tray. If there is not, load paper into the IN tray and press thec00153917.jpg RESUME button.
  • Do not load more than 100 sheets of 20-pound paper in the IN tray. The paper stack should not exceed 10 mm or .38 inches.
  • Use the same type paper in the paper tray when you are printing.
  • Makesure that the paper width adjuster is against the left side of thestack but is not blocking the stack. Push in the paper length adjusterto make sure that the paper is fully seated in the printer. Do not pushso hard that the paper buckles.
  • Do not use paper, envelopes, or cards that are torn, buckled, have curled edges, or do not lie flat.
  • Ifusing the IN tray to load several envelopes, push the paper lengthadjuster toward the envelopes until it stops. Do not bend the envelopes.
  • Load only one envelope at a time in the single-sheet input tray and be sure that it is inserted fully into the slot.
  • Use envelopes with square flaps instead of triangular flaps, or tuck the flaps inside the envelopes.
  • Ifthe printer's paper feed rollers become covered with debris (dust orpaper fibers), clean the rollers with a soft cloth dampened with water.
  • Ifthe paper loads unevenly in the printer, one or more of the rollers onthe rear access door is missing. Remove the rear access door and checkto see if all six rollers in the door are present. If any are missing,the door assembly needs to be replaced. This is a customer replaceablepart, number C4557-60076.
  • Ifthe printer does not drop any paper from the wings to the OUT tray,remove the excess paper. The paper stack should not exceed 10 mm or .38inches.
  • Ifthe printer is sending more than a single sheet through at one time,remove the paper from the IN tray and separate any sheets that arestuck together. Reload the paper in the IN tray.
  • Ifthe printer is not ejecting paper, then turn off the printer. If yourcomputer is turned on, turn it off. Then, turn on the computer. Wait afew seconds. Turn on the printer.
    NOTE: If you continue to experience paper feed problems, try other media or paper types. Refer to the User's Manual for supported media types and specifications.
Jul 09, 2008 | HP DeskJet 710c InkJet Printer
Paper in 3310 HP
You have a possible paper jam or foreign matter in your roller area or feeder area, get a torch and thoroughly check inside unit, near carriages, roller and paper feeder.
Aug 17, 2007 | HP Photosmart 3310 Printer
Canon Pixma MG5220 InkJet Printer Logo
50 people viewed this question
old marine
old marine
