Question about Dirt Devil SD20000RED Versa Power AllinOne Stick Vacuum Cleaner
How to detach versa power - Dirt Devil SD20000RED Versa Power AllinOne Stick Vacuum Cleaner
How and were do you empty the dirt?
Check it. When the bag is full, it's time to empty.
Apr 20, 2016 | Dirt Devil Red Versa Power Stick Vac
Power cable detached fropm vax
here is a video that will help you
Apr 28, 2013 | Vacuums
How do I put the filter bag in to dirt devil versa power
download the instruc.manual and proceed according. go to www.fitness.manualsonline.com or www. retrevo.com . God bless you
Jul 10, 2012 | Dirt Devil SD20000RED Versa Power AllinOne...
How do I get the suction over to the hand held hose?
Once you detach the hose from the power head, the suction is at the end of the hose.
User's manual:
http://www.eureka.com/service/manuals/80238.pdf
Dec 24, 2010 | Eureka Capture Upright Vacuum Vacuum
I am experiencing some (not complete) loss of sunction when I use the hose
Possibilities:
Dirty filter, needs cleaned or replaced.
Partially clogged hose, needs cleared. Detach hose from tank and drop marble down the end of the hose. It should roll through the hose and power head to the floor.
Partial clog in the power head between where hose attaches and the brush. Detach hose from power head and drop marble into opening. If the marble doesn't roll through, there's a clog that needs removed. You may need to disassemble the power head to do so.
Leaky hose, needs replaced.
Clog between back of tank and filter. This is where the hose attaches to the tank. Remove clog.
Clogged filter at bottom of tank, needs cleaned. Remove tank. There's a screen at the bottom of the tank/vacuum. Simply remove/clean anything that may be covering/clogging any of the holes.
Dec 18, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Belt works fine but there is no suction
This usually indicates a clog in the hose and airflow system. It's most likely to be behind the filter in the tank or in the power head area.
Detach hose from power head and look inside. If you can't see anything, try dropping a penny through it. You can also try dropping a penny through the hose itself to check for clogs in it.
Detach the hose from the tank and check just inside the hole.
Nov 26, 2010 | Hoover U5753-900 WindTunnel Bagless...
There is no suction when using as an upright
Detach the hose from power nozzle and check PN for clog. This is the most likely problem if the accessory tools work with the vacuum.
Nov 13, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a Hayden SuperVac 3600, almost 10 years old. The unit still runs, but now when I switch to the power nozzle, it doesn't have power to turn that. I think this happened once before and maybe they...
The hose has fuseable link inside, generally a 3-7 amp. It is at the wall end underneath the hose cuff. Easy to replace as it crimps in line. If you have a meter you can also test the detachable hose to wall cord for continuity, then check the hose to handle as well.
You can also detach the hose to wall cord from the hose, and plug your power head directly into that cord,, then into the wall thereby eliminating the hose itself.
Hayden makes a serviceable hose. If damaged or the fuse blown it can be serviced by a good tech. If the fuse is blown you need to clean and inspect the power head as this may be the cause
Jun 20, 2009 | Hayden Industries SuperVac 6000 Central...
No suction for use of crevice tools, running hot, then shut off
Obviously no suction in hose would indicate a blockage, over heating is a breaker that shuts off the machine when it over heats. There is no way to clean hose the on this model because the hose does not detach at either end, therefore I had to employ the use of the good old wire hangar. Job complete up and running, with good suction. It is amazing what a prayer to God can do.
Nov 17, 2008 | GE 106766 Bagged Canister Vacuum
Dirt Devil SD20000RED Versa Power AllinOne Stick Vacuum Cleaner Logo
27 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
