Question about Insignia LCDTV26 26 in. Television
Need screws for base mount on 50" DP50843 [t# os 1AAosDA0002 LCD
What are my options for a cracked sanyo dp50843 TV screen
Have screen replaced (search the net.) for prices on new and used or replace TV.
Feb 10, 2016 | Sanyo REFURBISHED DP50843 50IN 1080P 60HZ...
I am in need of a repair manual for a Toshiba Satellite L455-S5975 laptop in order to replace the LCD screen. I have searched everywhere, but no luck. Does anyone have a source? Thank you.
Not sure if you will find one... Process on toshibas is:
Pop top cover (sometimes also secured with a few screws on side or bottom of laptop) near monitor base above keyboard to access LCD cable and mount screws
Unplug cable and remove monitor mounting screws (Under plate, on back where cables plugin, and sometimes on bottom)
Take monitor (on flat surface) and remove screw covers with needle so you can put them back on later.
Remove all screws
Use plastic credit card and run around outside lip of screen case until removed
Remove LCD mounting screws
Remove LCD and inverter
Remove LCD brackets and inverter from panel
Replace panel and start working backwords.
Mar 31, 2011 | Toshiba SATELLITE L455-SP5016M LAPTOP LCD...
How to remove base so it can be wall mounted
Put LCD TV on a pillow, with screen resting on the pillow. Now the base will be free in air. Then remove screws at the back of TV, where base is joining. You might need a screw driver with magnetic head to remove screws. After removing screws, slide the base clamp out from the back of TV, and you are done.
Nov 01, 2010 | LG 32LG30 32 in. LCD HDTV
How do I remove the stand to mount the TV on the
the TV will mount to the wall via the VESA screw mounts on the back of the LCD. If it is a smaller, monitor sized LCD then the screw pattern will be either 75x75mm or 100x100mm. On larger TVs is it usually 100x200mm. Sometimes the base is screwed into this mount and othertimes to the bottom. Simply unscrew it from the screen. Be sure that the wall mounting kit can handle your LCDs VESA screw pattern, screen size and screen weight.
Feb 07, 2010 | Televison & Video
Type and size of screws to attach wall mount to viewsoni 17" lcd
Hi there!
Please refer to Page 7 of your VA1703w user manual for help on mounting this monitor, if you do not have the manual available, you can get it online here: http://www.viewsonic.com/assets/022/7368.pdf
From what I can tell, you may be re-using the screws that you remove during the listed procedure.
Feb 17, 2009 | ViewSonic VE710b 17" Flat Panel LCD...
Removing the base of flat panel tv
You don't have to mess around with the screws on the bottom of the base.
There are 4 screws on the back of the Toshiba that are in line with the wall mounting screw holes.
Remove the 4 screws and the base falls off.
Nov 23, 2008 | Toshiba Televison & Video
LCD Monitor
1st remove the base cover by by squeezing to release the clips and remove the 6 base mounting screws. 2nd remove the 5 screws in the back cover. 3rd push and pry at the parting line to release the clips. 4th remove the base mount by removing the two attaching screws and sliding it down about a quarter inch. 5th remove the steel cover by removing the 4 wires, two screws from power outlet, two bolts from vga plug, and the other screw in the cover. and there you have it.
Oct 26, 2008 | Acer AL1717 17" LCD Monitor
Removing base from tv
I researched this problem on the net and found the solution. Someone on one of the posts said the base can be removed by taking out four screws - all from the back of the TV. One screw is the one closest to the power plug, the next screw is beside it, the remaining two screws are the corresponding screws on the opposite side of the base panel (still on the back of the TV). Once these screws are removed the base comes off including the mounting bolt and the rectangular shaped plastic panel. There are no electronics or any components inside the base panel, only the bolt and plastic base which are held on by the four aforementioned screws. It was very easy to remove!
Apr 12, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
LCD
Most Protron and Ultra branded bases can be easily removed by just unscrewing them. Just a few simple screws and it should come right off. May need to flip it over and just take a look at where it's screwed into the TV itself. Hope this helps!
Dec 31, 2007 | Protron PLTV-37 37 in. LCD Television
Insignia LCDTV26 26 in. Television Logo
20 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
