Question about Sony Xm-d9001gtr Xplod Mono Block D Class 900 Watt Monaural Power Amp Aplifier
Other mosfet that can be used for fkv550 - Sony Xm-d9001gtr Xplod Mono Block D Class 900 Watt Monaural Power Amp Aplifier
How to fix sony 29'' wega, using irf 614 mosfet. mosfet is short
Check all the other component on board, associated with this MOSFET cirlcuit. Especially shorted zener diode, capacitor/s etc: Never replace an other FET, without check all the related component. It too will fail. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Nov 17, 2015 | Sony Televison & Video
Label parts motherboard
1) AC adapter (Charger) checks to be good?
2) DC Power Jack checks to be good?
(DC_IN.
The jack on the laptop that the AC adapter plugs into)
3) Then the problem is more than likely the Power MOSFET's on the motherboard.
May also include electronic components, that support the P.MOSFET's, too.
Multi-Layer Ceramic Capacitors (MLCC), that are SMD/SMT, just like the Power MOSFET's.
(Surface Mount Device/Surface Mount Technology)
Using the HP Pavilion dv6000, and Pavilion dv9000, series of Notebook PC's for an example,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
For these laptops the Fairchild Semiconductor Industries - FDS6679 - Power MOSFET is used, and the Alpha & Omega Semiconductor LTD - AO4407 - Power MOSFET, is used.
http://www.mouser.com/Search/Refine.aspx?Keyword=FDS6679
http://www.mouser.com/ProductDetail/Fairchild-Semiconductor/FDS6679AZ/?qs=sGAEpiMZZMshyDBzk1%2fWi1qxDdW%2fXBi2qgMuZEfLVO4%3d
http://www.mouser.com/Search/Refine.aspx?Keyword=AO4407
http://www.mouser.com/ProductDetail/Diodes-Inc/DMP3020LSS-13/?qs=%2fha2pyFadujguNNSgppBRqXbOxXLwzGsZm9SWxz1EqWpzoSJOpHpWA%3d%3d
Where the DC Power Jack is soldered to the motherboard, is the DC - DC circuit on the motherboard.
If the laptop uses a DC Power Harness, the DC to DC circuit is where the DC Power Harness plugs into the motherboard.
[Some models of laptops have a DC Power Jack, that has a small harness of wires coming off of it.
These wires end in a small male plug connector. The male plug connector plugs into the motherboard.
DC Power Harness ]
http://www.youtube.com/watch?v=3NN7UGWYmBY
http://en.wikipedia.org/wiki/MOSFET
http://en.wikipedia.org/wiki/Power_MOSFET
Regards,
joecoolvette
May 16, 2013 | IBM ThinkPad Computers & Internet
I have dell inspiron n5030. The power adapter light turns off when connected to laptop and hence not charging the laptop.
Bad Power MOSFETs.
Using the HP Pavilion dv6000 and Pavilion dv9000 series Notebook PC's, for an example,
General example of the -> package type, of the Power MOSFET/s used,
https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
The 'legs' (8) on the sides are Leads. This particular style is known as a J-lead.
http://www.youtube.com/watch?v=5uiroWBkdFY&feature=fvwrel
Using the Fairchild Semiconductor International - Power MOSFET - FDS6679 as an example,
$1.01 USD
Another component that may go bad are the Ceramic Capacitors, and near the Power MOSFET/s.
Looking at the first link, Mayohardware, look down at the second photo. AO4407
To the right of the Yellow circled AO4407 Power MOSFET, is a Ceramic Capacitor. Small rectangular shape with a wide dark band in the middle.
They burn, bubble, and blister just like the Power MOSFET's do.
http://www.mouser.com/Search/include/LargeProductImage.aspx?path=tdk/lrg/C3216%20Series.jpg
http://support.dell.com/support/edocs/systems/insN5030/en/sm/index.htm
http://www.radioshack.com/product/index.jsp?productId=2103245
Regards,
joecoolvette
Oct 08, 2012 | Dell Inspiron N5030
Part Number for internal battery charger - Presario V6000 series
Runs fine with AC adapter plugged in, but not with battery installed? Power MOSFET problem, or ceramic capacitor/s,
1) Using HP Pavilion dv6000 and dv9000 series as an example,
2) Information on MOSFET, and Power MOSFET,
MOSFET: http://en.wikipedia.org/wiki/MOSFET
Power MOSFET: http://en.wikipedia.org/wiki/Power_MOSFET
3) Basic example of a P.MOSFET used in a lot of laptops,
Notice the leads on the sides. Those are J-leads. Look at the shape.
Easy to unsolder.
If you are not adept at quickly, and properly, soldering an SMD in place, suggest you use a Clip Heatsink on each J-lead, when soldering the new Power MOSFET in place.
(One at a time)
[Surface Mount Device ]
http://www.radioshack.com/product/index.jsp?productId=2103242
If a Power MOSFET is bad it will blacken, and/or bubble on the surface, usually.
Will probably be one P.MOSFET on the top of the motherboard, and one on bottom of the motherboard, near where the DC Power Jack is soldered to the motherboard.
(DC Power Jack is the jack that the AC adapter {Charger} plugs into)
The rectangular objects close to the P.MOSFETS, and chipsets, are ceramic capacitors.
General examples when new, and different sizes,
http://images.search.yahoo.com/images/view;_ylt=A0PDoX5viWBQIyUAIAuJzbkF;_ylu=X3oDMTBlMTQ4cGxyBHNlYwNzcgRzbGsDaW1n?back=http%3A%2F%2Fimages.search.yahoo.com%2Fsearch%2Fimages%3F_adv_prop%3Dimage%26va%3Dceramic%2Bcapacitor%26fr%3Dmoz35%26tab%3Dorganic%26ri%3D4&w=2500&h=2195&imgurl=www.global.tdk.com%2Fnews_center%2Fimage_library%2Fimg%2Fceramic_capacitors.jpg&rurl=http%3A%2F%2Fwww.global.tdk.com%2Fnews_center%2Fimage_library%2F&size=788.6+KB&name=Ceramic+Capacitors&p=ceramic+capacitor&oid=695f61df8ab17293bd5cb84389e79153&fr2=&fr=moz35&tt=Ceramic%2BCapacitors&b=0&ni=21&no=4&ts=&tab=organic&sigr=11kdei2af&sigb=13bvkjeu7&sigi=127tmuie3&.crumb=ssehMErPqBD
Service Manual for disassembly, and reassembly,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=3177516&
Scroll down, click on -
Compaq Presario V6000 Notebook PC - Maintenance and Service Guide (3.28M), for the free Service Manual.
(After you click it may take up to 30 seconds before the first page comes up )
Make sure you wear an ESD wrist strap, (About $3 to $6), and have it's alligator clip attached to a good ground source.
Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws.
Advise Do Not mix them up.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 24, 2012 | Computers & Internet
Is there a device that I can connect to my inverter to keep it from shutting down due to voltage spikes from the vehicle?
Short of shutting the inverter off momentarily, there is not a simple answer. because you could slightly modify the inverter's over voltage reference IC, but that requires knowledge of the inverter that the manufacturer does not want you to know normally.
if you are running the inverter off a second battery, you could isolate that second battery from the system through any number of time delay relays, time delay circuits comparable to intermittent wiper circuits.
However, if you are capable with a soldering iron, MOSFETs can be utilized as a voltage variable resistor. They can be in a parallel array to increase current. You need to know what current draw is by the inverter with the normal load.
Once you know that current, you can select a MOSFET of sufficient "Constant Current" or pair of them and wire them as "Voltage variable resistor."
The circuit actually does work, the resistor is adjusted until you aproach the "pinch off zone" and tweak it to the point you want to operate with. The MOSFETs will need to be on a heat sink, any you can even wire a switch across them to short across them to remove them from the circuit. The image only shows one MOSFET, but they can be operated in parallel for more current capactiy. Which why the constant current rating of the MOSFET needs to be known. The type of MOSFET is not critical, it can be a trench fet, hexfet, etc. You should plan for double the current draw in your MOSFET selection for purposes of a design centered value. You can use up to about 5 MOSFETs from that one pot. For extra margin in the design you could add 0.1 ohm (2 Watt) resistor in series with each MOSFET to balance current through the MOSFETS, although MOSFETS will self equalize to a point. When they heat up their internal resistance goes up so thermal runaway is not normally an issue.
Jan 18, 2012 | Electronics - Others
SIR, I have a samsung lcd using mosfet
No,get the same mosfet IC.Mosfet dosen't function like a capacitor,capacitors up a litte voltage it no problems.
Mar 17, 2010 | Samsung SPN4235 42 in. Plasma HDTV
Mosfet check
1. Switch your multimeter to the Diode test position.
The following steps are for an N-Channel MOSFET.
Hold the Black lead to the MOSFET's source terminal.
2. Touch the GATE terminal momentarily with the Red lead.
3. Then touch the DRAIN terminal with the Red lead without touching the GATE terminal with your fingers.
The multimeter should show a low reading now. (The MOSFET is now ON)
4. With the RED and BLACK leads still connected to the DRAIN and Source terminals of the MOSFET, now touch the GATE terminal with your finger. The Multimeter should immediately show an open cct. (The MOSFET is now OFF)
This is a very simple way to test a MOSFET.
Jan 13, 2010 | Epson >>> IM800 DARK GRAY 733 MHZ CPU...
Trying to find the right FET to replace burnt up ones with
hafler use international rectifier hexfets. there is alot of confusion what constitutes a mosfet amplifier.
if the outputs are mosfets instead of bipolar transistors, it is a mosfet amp.
some designs are using mosfets to drive the switch mode power supply,but use bipolar output transistors.that is not a true mosfet amp.
you need to go to an electronic supplier for the repair industry.
or the manufacturers warranty depot,who will be able to order them.mosfets are very high current devices,you have to ask ...why did they fail. if they are the switch mode drivers,there is bad capacitors in that circuit
May 23, 2009 | MTX Thunder 5-Channel Amplifier 895 Car...
Mosfet in my asus motherboard burnt out,
Better to have the motherboard replace, do not wait until some other components might be also damage. Commonly mosfet is use in power supplies regulator. It can kill your processor and memory.
And also check your power supply. It might also having problems.
May 02, 2009 | ASUS P4GE-MX Motherboard
Sony Xm-d9001gtr Xplod Mono Block D Class 900 Watt Monaural Power Amp Aplifier Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
