Question about Kenmore Washing Machines
I hava a kenmore washer model #11023812100 and its not doing the last cycle which is the spinning what may be the problem
Serial #11023812100
SOURCE: Kenmore 90 Series Washer has slow spin cycle
Washing machine won't spin, seems locked up, when i turn the spin cycle on you can hear the machine trying to spin but it won't budge....... any suggestions???
Posted on Dec 28, 2007
  • 99 Answers
SOURCE: Kenmore 80 series
sounds like your control switch needs replacing.
Posted on Apr 30, 2008
SOURCE: 90 Series Kenmore Washer Not going to spin cycle not draining water
I've had the same problem...you can purchase a replacement lid switch at your local appliance parts store for about $35. Fortunatly, the sales person at the appliance store had diagrams and provided instructions to replace the switch. I was able to finish the job and fix the switch in less than 1 hour. Good Luck.
Posted on Jan 05, 2009
  • 12 Answers
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Posted on Jan 31, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
After rinse cycle won't washer won't spin
Sound like it could be a lid safety switch.
May 24, 2014 | Kenmore 22422 Top Load Washer
Kenmore Direct Drive Washer Slow Spin 11023812100
there is a switch on the motor check the wiring make sure it is working
Apr 05, 2014 | Kenmore Washing Machines
Kenmore washer Model 110, Serial No. 27602690 won't spin
If wash cycle operates and water drains as should before spin indicates motor spinning. Chances are bad timer If your a real fixer you can remove timer control from panel check and clean all contacts internally making sure none are stuck closed . (Have had 3 110s in my time).not easy but can be done or buy new about 150$ reassemble and check operation.
Mar 28, 2013 | GE WBSR3140DW Top Load Washer
I have a kenmore 23812100 top load washer that fills up, but stops prior to the draining stage for spin cycle. It just stops after the soaking cycle when its supposed to drain out to rinse. What could be...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11023812100/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
Also see the following for a more detailed description of how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part. See the Sears parts list with prices.
Jan 04, 2011 | Washing Machines
I have a kenmore 11023812100. no spin. bypassed lid switch and still no spin. does this model have any belts that could be loose? thanks, Gordon
Hi Gordon and welcome to FixYa I am Kelly. Your washer is direct drive for both agitation and spin. There is a centrifugal clutch for spin. If the motor is running and the unit is pumping out water then the clutch lining has failed.
See Item 6 this link:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11023812100/0582/0153200/P0111056/00005?blt=06&prst=&shdMod=
It can also be the motor coupling.
See this link under it pumps but doesn't spin:
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itdoesntspin
The video is a how to replace the clutch lining.
Thanks for choosing FixYa.
Kelly
Sep 27, 2010 | Kenmore 24642 Top Load Washer
Kenmore washer doesn't drain
This is likely a pressure switch issue.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2009 | Kenmore Washing Machines
Washer will not empyy water or spin or wash on any cycle
something caught in drain pump, clamp hoses and remove pump inspect repair or replace.
Apr 04, 2009 | Kenmore 22422 Top Load Washer
Washing Machines Logo
15 people viewed this question
Sal De
fordexpert
Robert Rankin
