Question about AT&T 1855 Phone
Answer machine just will not pick up
Answer machine will not pick up rings about 10 times and the stops
2 Suggested Answers
  • 3 Answers
SOURCE: Answering machine atarts working after 2 rings only
Press the 'Change' button
Press the 'Setup' button until you hear the voice say "Number of rings"
Then use the "Skip" and "Repeat" buttons to change the number.
Press the "Change" button to finish.
Posted on Dec 31, 2007
I need it to pick up on the 5th ring
The "Changing the Settings" section begins on page 10 of the manual. You need to go past the language and day/time to get to the number of rings.
http://www.home-electronics.net/USER-GUIDES/29875_DOM_EN_AN_IB.pdf
Jun 27, 2011 | GE 29875GE Digital Answering Machine
I have a Model MF 4150 , Serial No. JVM 73593 The Basic Guide that came with the purchase does not provide the necessary information. I have a phone on the same line as the fax machine (plugged into...
I'm going out on a limb here, and guessing it's a Canon imageClass MF4150... If not, please disregard this solution.
The advanced manual can be viewed / downloaded / printed here, directly from Canon:
http://gdlp01.c-wss.com/gds/0900006459/imageCLASS_MF4150_Advanced_Guide_EN.pdf
To stop it from interfering with the telephone conversation:
Issue: Fax interrupts telephone conversations in answering machine mode (AnsMode)
Solution: Setting the Receive Mode - ICMF 4150
  1. Press <Additional Functions>.
  2. Use <la.gif> or <ra.gif> to select [5 FAX SETTINGS], then press <OK>.
  3. Use <la.gif> or <ra.gif> to select [3 RX SETTINGS], then press <OK>.
  4. Use <la.gif> or <ra.gif> to select [3 RX MODE], then press <OK>.
  5. Use <la.gif> or <ra.gif> to select the desired receive mode, then press <OK>.
    round_note.gif - For [AnsMode], make sure an answering machine is connected to the machine.
    If [AnsMode], [FAX/TEL], or [DRPD] is selected, you can select some settings as below:
    [AnsMode]
    --- [AnsMode CHK TIME] (select time from 10 to 30 seconds for the answering machine to start playing outgoing message after receiving a call)
    --- [FAX DETECT TIME] (select the duration from 10 to 70 seconds for the fax to detect)
    [FAX/TEL]
    --- [RING START TIME] (select the time from 0 to 30 seconds for the phone to start ringing after receiving a call)
    --- [F/T RING TIME] (select the duration of ringing from 10 to 45 seconds)
    --- [F/T SWITCH ACTION] (select the action the machine will take after the ringing ends, Receive or Disconnect)
    [DRPD]
    --- [NORMAL RING]
    --- [DOUBLE RING]
    --- [SHORT-SHORT-LONG]
    --- [SHORT-LONG-SHORT]
    --- [OTHER RING TYPE]
  6. Press <Stop/Reset> to return to the standby display.
Apr 25, 2008 | Office Equipment & Supplies
Voice Mail
go iin option under ringers cheak to see whats its on before voise mail picks up 1 3 6 10 ? isnt it in the optimns menu or if u have seprate unit for voise mail cheak setting on that beofre it grabbs the call does that help
Jan 07, 2008 | Lucent 1872 Corded Phone
Our DECT2015 phone only rings 4 times and then stops.How cane I adjust the ringing time of our phone? Thanks Peter
Do you have voicemail or an answering machine? This is usually a sign that another device (fax, answering machine or voicemail service) is set to answer the call after 4 rings. You will need to lengthen to number of rings before the service/device in question picks up. (The method to reset this will depend on the service/device that is picking up.) Another possibility is a call forwarding service that is enabled at 4 rings.
I hope this helps. Please write back with details on the device that could be picking up for details on setting the number of rings. If you have voicemail or call forwarding, check with your telephone service provider to lengthen the number of rings before the service kicks in. (There are too many for me to know all of the providers instructions.)
Apr 16, 2011 | Uniden Lands Phones
Phone is plugged in to a fax machine and the phone rings too many times before answering machine picks up so the fax machine takes over. How can I reduce the number of rings so that the answering machine...
Change the answer machine rings to answer number to less than the fax number of rings to answer or increase the number of rings to answer on the fax machine. Would need exact model number of phone system to give more detail on programming steps. Info should be in manuals of phone system and fax machine.
Dec 07, 2010 | AT&T DECT 6.0 Cordless Phone System with...
I have philips landline phones. My main phone does not ring or flash when an incoming call comes in. I t won't go onto answer phone either it just rings out. I can pick it up and answer the call. i can...
Looks like the basic functions of the phone are correct. Remain the answering machine. Are you sure it can act as an answering machine?
If it can act as answering machine the reason it is not doing so may be the following.
  1. Answering function is turned OFF
  2. Answering function may be ON but the number of rings before it answers is set too high.
I suggest you try the following
Call you phone. Let it ring at least 10 times. If it can act as an answering machine it will pick up the phone and read the welcome message, because most answering machines (the recent ones at least) answer after 10 rings even if answering function is turned OFF.
The phones that can be answering machines usually do have a display that shows the number of incoming messages, or a LED that flashes to let you know that you have new recorded messages.
Jan 03, 2010 | Philips Lands Phones
Answering machine not picking up on 4th ring
Check to see if the battery needs to be changed. I did, and it worked for me.
Dec 16, 2009 | Radio Shack (43-3829) Digital Answering...
How do you set the number of rings on a brother 560 fax machine
Setting Ring Delay:
The Ring Delay setting determines the number of times the fax machine rings before it answers. If you have extension phones on the same line as the fax machine, keep the Ring Delay at a default setting of 4:
1 Press Function/Set, 2, 1.
2 Press < or > to select how many times the line rings before the fax machine answers (00 – 04) and press Function/Set. If you select 00, the line doesn’t ring at all.
3 Press Stop to exit.
Hope that's clear enough :)
Chris (ziraffa)
Nov 26, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Number of rings
Looks like 6 is the Max, according to the Manual.
Setting the Ring Time
Ring Time allows you to set the number of rings the caller hears before your
answering system plays the outgoing message. You can set the ring time to answer
after two, four, or six rings. If you enable the Toll Saver (TS), the answering system
picks up after two rings if you have new messages and after four rings if there are
none.
1) Enter the Answ. Setup menu, and then the Ring Time
submenu (see "Entering the Menu Option" on
page 16).
2) Press volume up/down to select a Ring Time (Toll
Saver, 2 Times, 4 Times, or 6 Times).
3) Press the OK soft key. You will hear a confirmation tone.
Toll saver is a feature where you can call the phone yourself, if there are messages it wil answer in 2 rings, if not it'll answer in 4 rings. The idea is to hang up on the 3rd ring and save the LD changes.
Hope that fixed Ya...
Geno
Mar 27, 2008 | Uniden TRU8885 Digital Answering Machine
# of rings before answering
Check to make sure you do not have distinctive ring option turned on.
Feb 05, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
AT&T 1855 Phone Logo
20 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
