Question about Water Heaters
Bought an old 1984 Terry Taurus Travel Trailer with no manuals and can not figure out how to start water heater
    Sergeant:
  • 201 Answers
See if control knob pushes in while in pilot posistion ,if so place in pilot posistion and keep depressed for at least 1minute after lighting pilot light then move to on ...gd luck chris
Posted on Jun 18, 2009
  • Ronald Maratas Oct 24, 2010
    I have a 1985 Terry Taurus and they are both similar in every way. First, press the blue knob and keep it pressed then turn it to the left until it stops. 2ndly, you must hear a sound like gas is coming through and go ahead and light a match and stick it into a large hole to the right. It should light up. adjust the gas flow regulator (it a slider with slotted holes) until you see clean blue flames. You should get hot water running in about 30 minutes or less.
Why hot water heater on my cedar creek travel
You needed to post more info. does it have power to the heater. Is it electric or gas? if electric and it has power to the heater you need to check with an electrical tester if there is power across the element terminals, If not it needs to be replaced
Oct 12, 2014 | Water Heaters
I would like to know how to turn on (run) 110 V for the water heater on a Conquest/Gulf Stream Travel Trailer?
Must be filled with water or elements burn out
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#new
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-water-heater-element.html
If water heater is plugged in and outlet has power... then water should be hot.
If no water inside tank, and tank is plugged in, and outlet has power, then element is burned out.
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 11, 2014 | Water Heaters
Tankless water heater for 2006 gulfstream cavalier travel trailer
What you really need to know is what the maximum flow rate and at what temperature you need. These do not store water, they heat it as it passes through.
Apr 09, 2014 | Water Heaters
Komfort 2003 travel trailer
There should be an ON /OFF switch inside, do you have power there? if you do you have a bad switch.
Apr 29, 2013 | Suburban Hot Water Heaters - All
Suburban hot water heater sw6p shooting out flames
Quit screwing around and shut gas off at tank valve and call a professional ASAP!!!!!!!!! This is a serious and quite dangerous situation. Fixya is full of people who think they know. This is a situation needing a hands on experienced professional,not a bunch of whining incompetent egocentric morons.
Dec 03, 2012 | RTO Suburban Rv Water Heater Dsi Gas Valve...
Our G6A-8E hot water heater started leaking shortly after being turned on. (We bought the trailer 2nd hand and this is our first time using it. It is a 2007 trailer so isn't that old.) We opened the...
I do not know the answer, or exactly which part is best to replace.
I would order all affected parts and have on-hand when work starts, otherwise you might be half done after a day of repair.
There are numerous blogs and self-help resources about atwood water heaters.
The following resource can help identify exact model number and part number for your specific heater. Plus maintenance tips.
The number of parts available and ez access to sellers of parts indicates these water heaters are frequently down, but are fully repairable.
http://waterheatertimer.org/Atwood-water-heater-resources.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 17, 2011 | RTO Atwood Water Heater - 6 Gal LP
I have a Atwood 10 gallon electric/ propane water heater on the Hornet travel trailer I purchased used. There are two switches on the wall, one is an on/off switch that lights up and the oither is just an...
The two switches control the water heater either in the gas or electric mode. The switch with the lights would be for the gas operation, and the switch without lights would be for the electric mode. Prior to operating either switch, make sure the water tank is full of water. Turn your hot water tap on, if water comes out, tank is full. Connect trailer to 110 Volt source, turn circuit breakers on, Place switch without lights to on position. If water does not heat in 45 minutes, Install new heat proble. The gas mode should be repaired by someone that is familiar with that system. Atwood can provide you with a local service center.
Oct 10, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Water Heater electronic ignition to work???
Here's a link to operators manual. You can download PDF file as well and print for later use if you wish.
http://bryantrv.com/docs2/docs/operating/atwood1.pdf
Apr 21, 2010 | RTO Atwood Water Heater - 6 Gal LP
2007 hot water heater leaking
You will be happier if you replace it
Repairs seldom last very long with this type of problem
Mar 21, 2010 | RTO Atwood Water Heater - 6 Gal LP
Water Heaters Logo
1,806 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
