Question about Craftsman 24 Hp 48" Deck Yard Tractor
Need manual for craftsman gt5000 mod#944.605070
24hp 48"cut
4 Suggested Answers
SOURCE: manual
goto sears.com click parts. type in your model # when page opens will be on the right of page asks if you would like to see owners manual you have to sign in to manage my home ****, but I found it there.its free just wants email address to send you junk mail.
Posted on Dec 15, 2008
SOURCE: the blades on my craftsman 22hpohv gt5000 won't
I would check to make sure that the pullys are free. With it off reach under and see if both or more blades turn freely. If the bearing is frozen it would cause this problem.
Posted on Jul 02, 2009
SeaDaddy46
SOURCE: Craftsman GT5000: Dies when switch is pulled to engage blades
I have the same tractor. If you have the transmission in <reverse> this will happen every time. It's a safety feature. Be sure the tractor is in <neutral> or one of the 6 forward gears.
Jim Romines
Posted on Jul 31, 2009
I need a diagram to show me how to route new belts on the mower deck of a craftsman gt5000 42inch deck please
Just a quick note here. Look under the left,sometimes under the right foot rest,for belt installation. Usually for the mower deck,its on the deck itself. Most i have seen was a decal. The owner,s manual has the belt installation guide,also. B. Locke
Aug 14, 2015 | Craftsman Garden
I have a craftsman gt5000 garden tractor 24hp els motor that threw a rod, the end cap broke loose.will the briggs and statton 27hp model 44Q777-3136-g5 work as new motor,the cranksaft dia. and length are...
There should be no reason why not, Just keep in mind of the bolt pattern and measurements as well as you may have to make a few altercations for cables but if shafts match you should be good to go! I hope this helps.
Sep 25, 2013 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a craftman GT5000 Lawnmower it quit charging were do i look for alternater?
The charging system is under the flywheel, but first check the 2 wires are connected at the side of the motor, they might be black and white at the conector.
May 01, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
The blades on my craftsman 22hpohv gt5000 won't
Hi, when was the last time you had the carburator serviced, secondly, you must check the governor to make sure it is working correctly under load.
Jun 30, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
One cylinder won't fire
You need to check spark plug wire to that cylinder I have had the same problem where a mouse ate insulation off wire ,Your engine has a coil with two wires one runs each cylinder I have had them go bad where only one fired you would need a new coil .
May 07, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Hi
Check for burnt fuse behind dash. If no burnt fuses check if getting power to magnetic clutch mounted on bottom of engine crankshaft. Make sure wires are not broken by magnetic clutch. Make sure the safety seat switch is working. Make sure you are sitting on the seat when you try to engage the blades. If that does not work try pushing and wiggling the seat sensor. Check make sure wire is attached to safety switch under seat.
Apr 04, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Replacing engine. Briggs 26hp on GT5000 garden tractor
Unfortunately, there is no single manual for this. It depends entirely on what crankshaft the OEM requested be used in the engine. You need to find out the diameter of the crankshaft and any threading to it, direction of the threading, etc. From there, a replacement can usually be found pretty easily. That or contact Briggs customer support (number in your owners manual) with the Model, Type and Code numbers off the engine. From this information they can see how the engine was outfitted for that OEM. Horsepower tells them nothing as those ratings and stickers are often replaced by the OEM and often NOT the information Briggs sends out on the engine.
Mar 07, 2009 | Briggs & Stratton Garden
Craftsman 24 Hp 48" Deck Yard Tractor Logo
200 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
