Question about Watches
I have an Exhilartion watch with a second hand ..how do set and start i?
4 Suggested Answers
  • 6 Answers
SOURCE: seconds hand starts ticking then stops
Your band may be too loose. This is the model that moves when worn correct?
Posted on May 13, 2009
SOURCE: Sweep 2nd hand operation & watch time setting on my Pulsar watch.
The larger second hand on the Pulsar PF8036 is part of the stopwatch feature. The upper button starts/stops the stopwatch feature, and the lower button operates the lap/reset function. Why they made the larger hand work only with the stopwatch instead of the smaller hand to the left is beyond me, but that's how it is designed.
Posted on Mar 25, 2010
watchandpen
  • 45 Answers
SOURCE: The second hand will not re-set to zero. It has
This is a symptom of what is usually several possible issues:
1) The most common is that the battery must be changed. Insist on Energizer batteries only (as they do not leak) and visit your local Certified Master Horologist for assistance in changing the battery and resetting the watch.
2) The movement must be serviced every 3-5 years by a qualified professional. Dust and debris can cause the symptom of stopping and starting the movement. If you have owned it for less time than this, remember that the watch may have been manufactured and in the retail location longer than this period of time before it was purchased.
3) The movement is defective or damaged. If the watch is under warranty, and it was purchased through an authorized dealer, Armani will take care of this issue for you at no charge.
To properly assess this issue, I recommend taking the first step, as a CMH also has the proper tools to test the movement and battery to determine the best next course of action.
watchandpen
Posted on Feb 25, 2011
Please can u show me how to change the time on this watch.
Set the time on your Baby G by switching to time mode. The button on the bottom left-hand side of the watch is the mode button. Pressing it once to will set the watch to time mode. The time digits will begin to flash.
  • 2Start by adjusting the seconds. Press the button on the top-right side of the watch once. The second digits will start to flash. Press the bottom right-hand button until the correct second time is displayed. Hold down the button to cycle through the digits. Once the correct time is displayed, press the bottom left-hand button and the digits will stop flashing. Press the bottom left-hand button again to set the hours.
  • Sponsored Links
  • 3Follow the same procedure to change the hours setting. Set the time and date by cycling through the digits in the following sequence: seconds, hours, minutes, year, month and date.
  • 4Press the bottom right-hand button to set the seconds to 00. When the second display is between 1 and 29, the digits will change to 00. If the display is between 30 and 59 seconds, the seconds will revert to 00 and one minute will be added to the minutes display.
  • 5Change from an a.m. to a p.m. setting by pressing the button in the middle of the bottom of the watch when any of the time display digits are flashing.
  • Nov 03, 2012 | Watches
    How to set the wr330 watch lost instructions.
    On the face of the watch, there are four buttons arranged around the circle of the watch face in four positions. Starting with the upper left hand button (labelled SET), and working clockwise around the face of the watch (to ADJ., EL, and MODE), I'll label the buttons "A", "B", "C", and "D".
    In other words...
    Button "A" is the button labelled "SET" in the upper left hand corner of the watch.
    Button "B" is the button labelled "ADJ." in the upper right hand corner of the watch.
    Button "C" is the button labelled EL in the lower right hand corner of the watch.
    Button "D" is the button labelled "MODE" in the lower left hand corner of the watch.
    Setting the Time.
    1. Press and hold D as if you were setting the alarm. As above, the stopwatch will momentarily appear and then after 2 seconds the alarm time will appear with the hour flashing.
    2. Press and release D and the seconds on the time of day will begin to flash.
    3. Press and release B to reset the seconds to zero provided they are below 30. If they are above 30, the seconds will reset and the minutes of the time of day will advance by one.
    4. Press and release A to change from flashing seconds to flashing minutes/flashing hours/flashing day of the month/flashing month of the year/flashing day of the week. In each flashing mode, pressing and releasing B advances the value by one unit.
    5. Press and release D to exit time setting mode.
    Mar 16, 2011 | Armitron Digital Sport #45/6967PNK Watch
    How do i set the time for my adidas ADP6002?
    The watch looks and feel great; the band doesn't hurt my wrist like other watches. The instruction book, however, was awful. It was a bunch of instructions for other watches, not the ADP6002. It took a few minutes of playing around for me to figure out how to set the watch. Here's how to do it: 1) Make sure there is a little "t1" above the second hand. If there is a "t2" instead, hold the Start/Stop button for 3 seconds. (This is the part that was messing me up) 2) Hold the Set/Light button for a few seconds. The watch should say LIGHT and "OFF" or "ON" should be flashing. 3) Press the Mode button until the hour hand starts flashing. You can adjust it up and down by the Start/Stop and Lap/Reset buttons. 4) Press Mode to adjust the minute, second, and other settings. 5) Press Set/Light button when you are finished.
    Jan 04, 2011 | Adidas Digi III Watch
    The 24hr hand is meant to keep time in another
    I too was confused at first at setting the second hand after reading the directions. I read your post in searching for a solution, then I figured it out. Check the watch face, the second hand is operating using military time. (24 hr. time) You will see 24 hour time embedded on the face.
    For example: if you wanted to set both hands to be at the same time to test this. At say 10 p.m. set the second time hand to 22 for 2200 hrs. (10 p.m.) Let's say you woke up at 7 a.m. The second hand would be at 0700 (Embedded on watch face) then at noon it would say 1200 on the watch face... I now use the normal hands for local time and set the 24 hour hand for my home time.
    I hope this helps.
    Dec 30, 2009 | Invicta Watches
    Cant set the second hand to move
    The "second" hand on this watch is not actually a 'sweep' second hand, as on other watches.
    This is a timer dial. ["Stopwatch 1/5 Second Hand"]
    To start/stop this, use the top button (Button "A").
    To reset this dial to 12 O'clock, use Button "B", after first stopping it with Button "A".
    The "second" hand is the small dial at the 9 O'clock position.
    In actuality, you 'could' start this and just not stop it...  Then it would function as a "large second hand". That would be up to the owner. (it might use more battery power though... ?)
    Nov 11, 2009 | Pulsar Chronograph Watch
    Hi, The second hand and the digital seconds aren't the same...do I have to "reset" the watch. I tried pushing A and B at the same time.
    When in the time set mode pressing the bottom button when the seconds field is flashing will return the seconds to "00" You should be able to correct the seconds this way. If this is not working then reset the watch and start the set process again.
    Here are instructions for setting this watch.
    http://www.geocities.com/watch_crazy/skyhawk/setting/setting.htm
    Sep 20, 2009 | Citizen Blue Angels Skyhawk Watch
    Brand new watch and second hand is not ticking. The watch has a crown and 3 buttons, the crown only pulls out one level and 1 button is mode, the other set/start/stop and third El (illuminates). Is there...
    Yes, unfortunately the seconds hand, or, to be more precise, seconds wheel is faulty. There is nothing you can do yoursef as this fault requires attention and knowledge of watchmaker.
    Find your nearest watch repair shop and ask for help.
    Rate me, please.
    Mar 25, 2009 | Giorgio Armani Donna AR5497 Wrist Watch
    Getting analog part of Mossimo watch to start
    FIXED!!!
    As it turned out these Mossimo ANA/DIGI watches use two different batteries, one for the digital part (big) and other for the analog mechanism (small).
    Have the watch serviced to change the second battery and VOILA!!!!
    Enjoy!
    Mivales.
    Made in Costa Rica!!
    Sep 01, 2008 | Watches
    Oct 09, 2007 | Watches
    Watches Logo
    11 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
