Question about John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter
Where do you change the oil on an srx75 - John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter
John Deere RX 75. What type of oil does it use? any other suggestions?
The wrong oil won't stop an engine from starting but the right oil will help it to last longer. Buy a respectable brand and there will be an application catalogue making recommendations for which of that brand's products are best in which engine.
It is little use changing parts and hoping. You need to be checking for a good quality spark and for the presence of fuel getting into the cylinder.
An engine needs compression and the right amount of fuel delivered into the cylinder and ignited at the right time by a spark of sufficient quality. An engine that doesn't start has at least one of those requirements missing. The challenge is to discover which...
May 13, 2016 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
What type of oil does it use? John Deere RX75
some use straight 30 some 5-30 others 10-30 jd has their own oil as well the following chart showes the type
May 12, 2016 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
What type of oil doe it use
10W-30 Turf Gard
http://www.greenpartstore.com/John-Deere-GF-3-10W30-Turf-Gard-4-Cycle-Motor-Oil-Quart-TY22029.html
JD SRX75 - when push lever forward or back, tractor does not move..
check the lever on the rear of the tractor used to puch the unit when not running then check the belt
Mar 31, 2012 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
I am having difficulty getting the nut off to change the oil on my JD Rx75. Any suggestions or could you explain the procedure.
If your mower is a GX 75 it has a brass square nut on the back of the engine.
Use a open end wrench and turn a few turns and it will open a valve to drain the oil.You can unscrew it until it stops turning.Dont over do it.
Their is a hose that attach's to the valve so you can drain it to a bucket or drain pan.
So you are just turning a valve, if it doesn't drain look for dirt or stuff plugging the valve.
May 02, 2011 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
My John Deere srx75 was running good I shut it off and now can't get it restarted. The battery is fine and when I turn the key there is no sound at all.
Hold key in the start position and move or wiggle the transmission lever a little; you'll hit the sweet spot and it will fire!
Sep 08, 2010 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
