Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
WHIRLPOOL LT5000XSN2 DRYER HOW TO REMOVE DRUM TO REPLACE SEAL?
  • 121 Answers
Hello Maryann,
I would like to tell you but its best to know how to take the machine apart,
The drum seal is located in front of drum, which means you need to take front of dryer cover off
Posted on Jun 18, 2009
Felt seal on back part of drum whirlpool
Felt seal and glue
What I would do is take the dryer apart and remove the old drum seal. Get as much of the old glue off there and install new felt. I tuned upa dryer built like yours not long ago and took some photos.
Roper dryer tuneup
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 02, 2011 | Whirlpool WED5300S Electric Dryer
Have a year old whirlpool dryer accudry sensor drying, sounds like tub is off balance. Can lift up front of dryer & loud noise stops. What might problem be?
Hi idosmiles06...
The noise you are hearing is one of three things...depending on your dryer.
1...Front felt drum seal needs replacing...rubbing metal to metal
2...Drum rollers are worn and needs replacing
3...Drum bearing is worn and needs lube or replacement...if your is the kind of dryer that has the center support bearing.
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like the drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear they will make a thumping type of noise.
If your drum rollers have too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them and are only squeeling then they probably only need lubrication.
Remove the rollers and clean the shafts that the roller rolls on, remove any hair,dust,etc from roller and shaft.
Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
Please take time to rate me thumbs up
Sep 23, 2011 | Whirlpool Dryers
Whirlpool gas dryer model WGD9400swo has thumping, is it the drump or support rollers and how much do parts cost?
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
The rollers are not very expensive, for your parts go to: http://www.partselect.com/
This is a FREE answer, Please rate me
Oct 10, 2010 | Whirlpool Dryers
What is the process for replacing the drum bearings for my thin twin LT5000XSN2. Need step by step. Sounds like is about to fall apart. I am very good at fixing most things.
The problem is usually not the bearings at all but the felt guides on the front of the drum. The felt wears off and then makes lots of noise. You can access this part by removing the front along with the door. Listen close with the button in and door open to see if the noise is coming from the front or rear.
Aug 19, 2010 | Whirlpool LTE6234D Top Load Stacked...
Brown marks left on clothing -- occasionally My dryer is not gas but electric but that wasn't a choice on here.
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Drum has sagged in front ,bad rollers or drum support? motor wont turn drum enless i kinda lift front of drum .i dont have the manuel.Dave
Hi and welcome to FixYa. I am Kelly. If you can provide me with a mmake and model number I can tell you exactly what parts to order and change including the source to correct the problem you describe.
These parts are in most cases are:
1. The drum bearing ring: (not always bad)
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Bearing-ring-for-front-support-item-number-AP2996731.aspx
2. The front drum (Replace)seal: http://www.appliancepartspros.com/part_details.aspx?part_id=3131525
3. The rear drum seal: (replace) http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Rear-drum-felt-seal-with-adhesive--red-thread--item-number-AP3094149.aspx
4. Roller kit and belt: (replace) http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Dryer-repair-kit--29-inch-large-capacity-models--item-number-AP3131942.aspx
These are the most common failures. I would recommend ordering and replacing all parts 2 - 4. Doing this will ensure your dryer will last for a long time trouble free. (tumbling)
See this manual for general help: (Important)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794/$FILE/4322260.pdf
Thanks for choosing FixYa.
Kelly
Jul 29, 2010 | Dryers
I have a whirlpool model LE7680XSW2 thats runs fine but the top surface seems to be getting hotter than my wife remembers. Is this a sign of over heating
Sounds like the rear drum seal on the drum its self is bad . Have to remove the drum and replace Pt # 279408 . When the seal is bad , dryer gets hot , right up in front of the console , in the center .
Jul 28, 2009 | Whirlpool Dryers
Whirlpool duet dryer felt seal replacement
The drum may to be removed to install the new felt gasket but the old drum can then be reinstalled. The felt gasket seals the joint where the drum rotates at the inside back panel. It is likely that the inside back panel can be removed when the dryer is placed front-down and the outside back panel is removed. In that case the drum does not have to come out.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
A white piece of insulation or maybe a gasket came out of the dryer, how do i fix it.
This sounds like the drum seal gasket, about 2 in. wide. The drum has a black rubber type gasket and the gasket you found is attached to the dryer. You will have to remove the drum to replace this gasket.
If you want to DIY, I can give more info.
Jan 22, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore he4 dryer model # 110.85089400
drum seal tends to change to a rust color after a few years of use 2 options replace both front and rear seal(best) or remove drum and try to clean both seals with bleach /water solution or spray cleaner with bleach ..if seals are not worn to bad this may work as a tempory fix
Jul 04, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
488 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
