Question about Kenmore Washing Machines
Kenmore Model 110 does not agitate or spin - Kenmore Washing Machines
  • 129 Answers
SOURCE: Agitator not spinning
could'be water level switch or timer control. another posibility is corrosion on the motor wiring connector
Posted on Jun 22, 2007
appldoctom
  • 311 Answers
SOURCE: KENMORE WASHING MACHINE MODEL#110. 254872300 WONT SPIN
if your sure it will agitate?[because the pump is on the other side of the motor and will drain,but if coupler broken ,wont agitate or spin although it makes noise like its working.so if will truely agitate drive coupler fine and its going to be the clutch or that area unless somthing[clothing] is between the two tubs creating anough resistance to stop the tub from taking off.clutch pads will just slip on drive plate.hope that helps>God bless ,tom
Posted on Jan 04, 2009
SOURCE: Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Posted on Jul 04, 2009
jsrock516
  • 5911 Answers
SOURCE: kenmore model 110 will not drain or spin?fills
Check your lid switch. The symptoms of your washer stopping at the rinse cycle is a commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30. Prices differ between these sites, so shop and compare. If you still have questions, please let me know. If the suggestions I have listed do not match your washer symptoms, please post back and elaborate more on what the washer is/is not doing so I can provide you with better assistance. Please include your model number if different from the one listed. I hope this information is helpful to you.
NOTE: "110" is not the model number. This is the prefix on the model number that identifies the manufacturer of your washer. 110 indicates the washer was manufactured by Whirlpool.
Posted on Nov 26, 2009
allbrands
  • 600 Answers
SOURCE: My kenmore 80 series model
Hello, Thank You for using FixYa. I will be helping you today.Sounds like something stuck in pump. If you lean the unit back the white plastic pump is in the front two clips hold it on.First disconnect the hoses from the pump and see if something is stuck in there. Im sure this is the problem.
Thank You and please rate my answer if it was helpful..
Posted on Jun 15, 2011
Kenmore Washer Will Not spin
replace door switch ,good luck APPLIANCES R EN
Mar 03, 2013 | Kenmore Washing Machines
My Kenmore 70 series is 18 years old. It will not
Hello. Since your machine is 18 years old and the agitation/spin is costly to repair I would definitely recommend a replacement washer.
Jul 06, 2009 | Washing Machines
Jun 30, 2009 | Kenmore Washing Machines
Machine agitates but doesnt spin or pump out water
you will need lid switch 285671.. whirlpoolpartssurplus.com
Jun 24, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Kenmore won't agitate
the model# starts with 110. Sounds like you have a broken motor coupler. Its part 13 on diagram. part #285753
Dec 15, 2008 | Kenmore 44102 Front Load Washer
No agitator action
I need to get the model of the washer. (e.g. 123.123456789). This will greatly help to identify the problem and a fix for the washer. Thanks
Jul 07, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
24 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
