Question about Kenmore Deluxe KSR400 Iron
Can't turn the iron off - Kenmore Deluxe KSR400 Iron
Rowenta surfline iron turned off and won't go back on.
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jan 27, 2010 | Rowenta Surfline Iron DE-333 Iron
Iron will not turn on
heatman101
Jan 27, 2010 | Euro-Pro G1490 Continuous Iron
Iron turns off by itself while using it. I have to move the cord around in order for the iron to turn back on.
you may have a bad connection in the cord wires will need a new cord replacement or new iron
Dec 11, 2009 | Rowenta DZ5080 Iron with Auto Shut-off
My Shark Iron leaks....
fill with water turn iron on max keep turning steam dial all the way to the right until you get to self clean hold iron horizontal and make sure you have a towel or something to catch water drips and debris coming out of iron let iron steam and spit water out until it stops on its own turn dial back to regular steam settings wipe residue off of the plate with a towel adjust temp settings back to normal
Aug 14, 2009 | Euro-Pro Shark GI490 Iron
It shuts itself off
The SHARK ELECTRONIC Iron is equipped with an electronic auto-off. The electronic auto-off switches the iron off if it has been left standing unmoved in any position (sideways, flat or upright) for approximately 7-9 minutes. A red light on the LED display panel will flash when the iron switches itself off. (Fig. 7) To switch the iron back on, just shake the iron side-to-side several times.
Jul 31, 2009 | Euro-Pro Shark GI490 Iron
Rowenta Steam and pressure iron does not turn on
heatman101
Apr 20, 2009 | Rowenta DG-980 Iron
Shark euro pro G 1400z
how do you replace the light bulb on a shark euro-pro iron?
Oct 27, 2008 | Euro-Pro Shark GI475 Iron
Auto shut off
either the element is faulty or the switch you turned to give the diffrent tempreture has solder, if it is lose then your iron can repair if it is the element then you have to buy a new iron.good luck.
Sep 06, 2006 | Tefal UltraGlide plus 1656 Iron
Kenmore Deluxe KSR400 Iron Logo
Top Kenmore Irons Experts
Steve
ray gallant
Tom Chichester
Are you a Kenmore Iron Expert? Answer questions, earn points and help others
