Question about Intel Computers & Internet
Chiavetta usb d33193
DONOT OPEN
My windows 7 can not detect my jetflash transcent d33193
This answer is based off my opinion however, windows 7 is rubbish. Update when you can.
It could be many different possibilities.
1. Try your usb in another pc to make sure the usb is ok
2. Try different USB's inserts on your pc.
3. Format your usb on another pc then try again
4.if your computer is old it could come down to USB 3.0 compatibility issues.
5. Use a usb switch
Update to windows 8.1 or 10 when you can. You will be a happier person
Aug 25, 2016 | Electronics - Others
Usb d33193 4g
Try formatting with RMPrepUSB. If it doesn't see it, take it apart and resolder the 4 contacts.
Oct 09, 2013 | Electronics - Others
My 8 gb Transcend D33193 is not detected.
Try to download software called USBDLM install it to the computer. Then it will auto detect your USB if your flash drive doesn't have problem on the hardware itself. If there is a hardware problem reformat or run scandisk USB disk.
Mar 19, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have TRANSCEND D33193 when i try to format, I have TRANSCEND D33193 when i try to format, or delete files from it, it shows YOUR DEVICE IS WRITE PROTECTED!
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
Jan 14, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My pen drive is not open (mic d33193)
u need to formate your pen drive, with low level formatting.
Jan 04, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I am having D33193 Transcend Pen drive (1GB). For last few days, due to some problem, computer does not detect it. That means, in my computer/exporer, I am unable to see it. Any solution? Thanks in...
I think you are getting the error message unable to recognizance and having malicious functioned
Please restart the system in safe mode and try to connect the drive and format with command prompt
or try to connect in any other having Linux operating system
Jul 28, 2010 | Electronics - Others
Transcend D33193 Problem
Try transcend D33193 another port back side on cup or front side on cup
Jul 11, 2009 | Microsoft Windows 98 for PC
Computers & Internet Logo
70 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
