Question about Car Audio & Video
Holden captiva display
I have a 2008 LX 60th edition, and the 7" display panel wont turn on, nor the reversing camera. I don't know which fuse this is to check Please help
  • 2 more comments
  • Matt
    Matt Apr 13, 2014
    Thanks Frank, but the manual doesn't directly indicate which fuse(s) relate to the display panel.
  • Matt
    Matt Apr 13, 2014
    FYI, its the unit which displays the radio stations/DVD's/compass/heating controls etc.
  • Matt
    Matt Apr 14, 2014
    After much deliberation, I plumbed for removing and replacing fuse number 13 (Audio) 15A.
  • Matt
    Matt Apr 14, 2014
    It worked, and it did not need me to enter a Radio PIN code. Happy :-) Thanks all
    New Friend:
  • 180 Answers
Check the owners manual for fuse replacement.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
Posted on Apr 13, 2014
3 Suggested Answers
smarthome2
  • 1114 Answers
SOURCE: I lost thr driver's instrument display on my
The switch for your dash lights is probably bad. (The rotary dial to adjust dim to bright) can you still turn on the interior lights with the dial? it will "click" when in the fully bright mode and turn on the interior lights. If so, put a dark towel over the dash to mask the interior lights and look to see if the dash lights are on. If they are on, you've found the problem. (very common) Hope this helps
Posted on Jun 23, 2009
rteemon
  • 578 Answers
SOURCE: I lost my driver's instrument display on my holden
does unit still work when that happen
Posted on Jun 27, 2009
Hello I just bought a holden captiva 2007 lx. when I drive it all the lights comes on and when it changes gears it jumps
I think you should buy repair manual first for your vehicle after that it will be easy for you to solve the problem. Check the link may be you will find something useful here
holden
Dec 05, 2017 | Holden Cars & Trucks
Is anyone having issues with the touch screen on the 2016 Holden Captiva freezing?
Hi Rob sorry to hear your having problems with your Captiva. Did you buy this vehicle new? not that it makes any difference as it should be covered under warranty. Unfortunatley this must be a difficult fault for the dealer to reproduce. You mentioned you had other faults with the vehicle,are they related ie electrical faults or mechanical. There is no reason why you should not just turn up when it happens for the Dealer service manager to view at ist hand and for him to take a video of this annoying fault. He can then submit this info to Holden on your behalf. Hopefully they can then get the ball rolling to find a fix. Good luck.
May 11, 2017 | Holden Cars & Trucks
I have a 2007 holden captiva that winds over but wont start
Is there an anti theft device? Check all fuses. For example A blown ECM fuse will give u fuel pressure and spark but won't start.
Aug 25, 2016 | Holden Cars & Trucks
Holden captiva rear door handle broken with child lock on..?
If door is in jammed state, open door by
repeatedly pressing the unlock button, while jiggle the inner or outer door handle this will help free up the
internal gears in the actuator that are jammed.
once the door is open.
Replace the door lock actuator with a revised
part;
Part No.: Description Qty:
96872800 LOCK,LHF DOOR (SX, CX, LX) 1
96872801 LOCK,RHF DOOR (SX, CX, LX) 1
96872811 LOCK,LHR DOOR (SX, CX, LX) 1
96872812 LOCK,RHR DOOR (SX, CX, LX) 1
96872803 LOCK,LHF DOOR (MAXX) 1
96872804 LOCK,RHF DOOR (MAXX) 1
96872813 LOCK,LHR DOOR (MAXX) 1
96872814 LOCK,RHR DOOR (MAXX) 1
Vehicle Torque Spec for door lock actuator
Captiva SX,CX, LX 10 Nm
Captiva MaXX 8 Nm
Apr 13, 2016 | Holden Cars & Trucks
How to reset engine light ? Holden captiva 60th anniversary model.
That will just reset your oil change light. you need to hook a scan tool to the vehicle and repair what problem it tells you the vehicle has.
Aug 03, 2014 | Holden Astra Cars & Trucks
2007 holden captiva air bag light staying on
Hi Jeremy!
WOW! thank you very much about your tips!! I fix my airbag light just moving the yellow wire under my driver seat at NO COST!!
I got Captiva LX 2007 and the airbag lights on for month and I know Holden dealer charge a lot for any repairs!
Airbag light on - fixed now!! Thanks again!
Now i need to fix my Engine light - Holden dealer quote me for 4K-6K to replace the timing chain..
I got quote from the local mechanic for $2400 ---- a lot cheaper!!
Cheers
MItz
Dec 09, 2013 | 1999 Audi A6
How to remove stereo from 2008 holden captiva lx
firstly remove the negative terminal of the battery then just gently remove the air vents with screw driver by gently pulling the corners after that the four corner screw driver is used to remove all the screws then pull out the stereo and remove the coupler behind it
Sep 17, 2013 | Cars & Trucks
Holden captiva lx brake lights not working
It is common for the plastic brake light switch to get jammed or brake. Remove and make sure small centre rod moves. To remove just turn and release light a light bulb. If switch fails it will prevent brake lights and can also prevent gear selector to move and also make brake pedal feel spungy.
Feb 28, 2012 | Cars & Trucks
I lost thr driver's instrument display on my holden captiva LX. All the fuses OK. What needs to check?
Jun 23, 2009 | Car Audio & Video
Car Audio & Video Logo
371 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
