Question about Garden
Fuel filter won't fill - Garden
2 Suggested Answers
  • 10 Answers
SOURCE: fuel filter won't fill up
Fuel pump weak, fuel filter dirty, carb./injectors clogged, bad gas?
Posted on Jun 14, 2013
Replaced fuel tank now tractor won't start. It cranks good but just won;t start.
Probably have air in the fuel line not letting any fuel getting past, it will collect at the highest point..
If you have inline filter replace with a drill pump to suck fuel along pipe, or to force fuel back to tank, you will also need to fill the part that is post filter point
Sep 29, 2015 | Cars & Trucks
Fuel filter won't fill up
Jun 14, 2013 | Cars & Trucks
'05 ford escape - car won't start if fuel below 1/4 tank
Not sure about P0195, but P093 is for a problem with the fuel rail pressure sensor. The sensor could be faulty or it could be accurate when the fuel system is empty.
Your sending unit for the fuel gauge could be off. Can you check the amount of fuel it takes to fill the tank when the gauge reads half ? If the gauge is right it should take half of the capacity of the tank to fill it up.
Dec 06, 2012 | 2005 Ford Escape
The evaporative system failed on emissions for my 87 Ford Ranger 2.9l engine, any suggestions what might be wrong
It can't be filled up because it leaks, or won't take anymore gas? Check the hose from the fuel filler to the tank for kinks or restrictions, if you have leaks, fill it up and trace the leak. Either problem will cause EVAP codes, hard starts, and cause vehicle to die.
Oct 03, 2012 | 1987 Ford Ranger
Ford 2001 f250 v10, ran out of gas, filled tank and still won't start
check for fuel pressure at fuel rail if no pressure or low pressure check and change fuel filter while ya have it off or it could be relay switch that would be the least expensive place to start good luck
Oct 15, 2011 | 2001 Ford F250 Super Duty Super Cab
2004 Saab 9-3 Aero. replaced fuel pump aprox four month ago ( @ Aprox 100,000 miles), the last two fuel fills I have smelt gasoline in and around car (no visable leaks). Check engine light came on 1 week...
While a fuel filter won't normally cause the check engine light, it could cause other errors that would trigger the error light to come on.
Since fuel filters are easy to change and not very expensive, I would change it and see would happens. But you might also want to run a pressure test on your fuel pump also.
Jul 08, 2011 | 2008 Saab 9-3
2004 z71 tahoe when the gas gauge is at a quarter of a tank it won't crank. It acts like it is empty with gas.
Check your fuel filter if it needs replacement. Empty it out then connect it back. Try to start it again. Inspect the fuel filter if it filled with gasoline. Check if there is noise at the fuel tank to check if the pump is working. If it did not, inspect the fuse for your fuel pump and the relay. If both are good you may connect the fuel pump directly to the battery to see if it works. It may be a bad wiring.
May 08, 2011 | 2004 Chevrolet Tahoe
Starts but won,t keep running seems fuel starved still quites with the choke full or half or off homelite 33cc ut10947 thank you
Possible fuel starvation, pull the fuel pipe out of the tank through the fill hole and replace the filter on the end, let us know how you get on,
Feb 05, 2011 | Garden
Skid steerer won 't start
You need to remove the fuel filters and fill them with fuel, and them if you engine is equipped with a primer,,,,prime the fuel system.
Simply filling the fuel after a run out will never start it. The system has air in it that needs to be primed out.
Aug 03, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
11 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
