Question about Canon imageRUNNER C3220 Color Copier
Canon ImageRunner C3220 Error Code E000751-1303
KyoDoc
  • 38 Answers
SOURCE: Canon imagerunner 2200 error code E000602-0003
This is hard drive failure. If you another code other than 003 you may have gotten away with a scan disk, but not always. in your case the hard drive has died. a Canon Technician will need to replace it and re-install the machine's system software
Posted on May 08, 2008
SOURCE: E000001-0000 error code
it s a thermistor problem
to clear the error do the following.
press additionel functionel* button & press 2&8 at a time &press additionel functionel button* select COPIER>FUN CTION>CLEAR>ERROR>OK.
Posted on Aug 14, 2008
checkitright
  • 1362 Answers
SOURCE: How to get in service mode on Canon ImageRunner 1630
You DO NOT WANT TO RESET THIS ERROR CODE !!!!!!!
there is a problem with the fuser, if you reset it most likely it will melt the rollers in the machine.
check the lamp (burn out), and thermofuse. replace
Posted on Oct 16, 2008
SOURCE: ImageRunner 2230 Error E000001-0002
canon copier e000001-0002
Posted on May 11, 2009
canontech
  • 1219 Answers
SOURCE: Canon image Runner 1023
E197 0000 Printer engine communication error
Erroneous communication between the DC controller PCB and
image processor PCB was detected
- Check the connectors of the DC controller PCB and image processor PCB.
- Replace the DC controller PCB for normal connection.
- Replace the image processor PCB.
Posted on Jun 30, 2010
How to repair canon ir C3220 Error Code E602-0003
This is just a shot in the dark, but if there is no "reset" button, you might try unplugging it for a couple of minutes and it should reset itself to factory default settings. Just a guess. If you have an owners manual, I would check there to find how to solve the problem. You might want to enter the "menu" if there is one, and discover whether you can solve the problem there. If you don't have an owner's manual, you might be able to find one at the printer manufacturer's website in the support section.
Nov 11, 2013 | Canon Color C3220 Copier - Color...
Error code 000804-004
www.digitalcopiersolutions.com/clc-3220.html
Color Copier Canon ImageRunner C3220, Canon's true definition of multifunction has been met. should find all on here x
Mar 14, 2013 | Canon imageRUNNER C3220 Color Copier
Error code E000003-0001on Canon ir C3220
this is problem with the thermistor .
because the fixing temperature doesn't rise. maximum rise up to 70 degrees C.
solution is change the thermistor with a new.
Jul 21, 2011 | Canon imageRUNNER C3220 Color Copier
I have error code 00001-0005. in my printer
This is telling you that you have a faulty capacitor, and it is in need of replacing.
Mar 27, 2011 | Canon Color C3220 Copier - Color...
E000732-0001
scanner communication error
Jul 01, 2010 | Canon imageRUNNER C3220 Color Copier
I have error code E00580-000 for my cannon imagerunner copier model C3220. Can anyone help me.
error is related to the finisher(stacker up-down movement). the hight sensor may have a problem
Nov 16, 2009 | Canon imageRUNNER C3220 Color Copier
Canon Imagerunner 2200 with error code e000000-0000
Try to enter service mode, and from function clear the error.
Switch off and on. If the problem persists you have a problem with your fixing unit...
Sep 02, 2009 | Canon imageRUNNER C3220 Color Copier
Canon Imagerunner 2220i Error Code E000000-0000
canon printer ir 2200 error E000000-0000 my help
Feb 05, 2009 | Canon imageRUNNER C3220 Color Copier
Canon imagerunner c3220
Were the heaters at fault. It is more like a thermister problem. Replace the thermisters, both. And I would also change the thermostat as well. When you are sure thatyou have removed the faulty unit reset by doing the following.. service mode/copier/function/clear/error followed byswitching the machine off and turn on again.
Oct 31, 2008 | Canon imageRUNNER C3220 Color Copier
C3220
check to make sure cables are all plugged in properly ..is normally a bad connection between the scanner and printer
May 23, 2008 | Canon imageRUNNER C3220 Color Copier
Canon imageRUNNER C3220 Color Copier Logo
54 people viewed this question
old marine
old marine
