Question about Canon PowerShot SD1400 IS IXUS 130 Digital Camera
Movie mode not responding
Camera does not go to move mode when selector to movie mode
Maytage Dependable Care washing machine will not operate. Lid switches, timer check out. Fuse is good. Machine is getting power. Machine will not fill, agitate, or spin. Timer does not advance.
Sounds like the timer motor is fried. Remove it, connect it to a 110/120 volt power source and listen to it. If you can hear it running, then that's cool. Next, move the selector switch to the next mode manually and see of your machine responds to that. If it does, then the motor for the timer needs to be replaced, it probably lacks the torque needed to move the selector switch around.
Jan 23, 2014 | Washing Machines
Shooting in black and white --i don't know what is the problem --need help
1. Set the Power switch to CAMERA.
2. Set the Mode switch to TAPE. (VP-D353(i)/D354(i)/D355(i) only)
3. Press the MENU button.
4. Move the Menu selector to the left or right to select Camera, then press the Menu selector.
5. Move the Menu selector to the left or right to select Digital Effect, then press the Menu selector.
6. Move the Menu selector to the left or right to select the desired Digital Effect mode, then press the Menu selector.
7. To exit, press the MENU button.
Feb 18, 2011 | Samsung SC-D353 Mini DV Digital Camcorder
Remote control not responding batteries good
You can simple test your remote control if you have a digital camera. Usually the camera has photo (picture) mode and video (movie) mode. Switch it it to video mode and see on the screen if your remote control flashing when you press buttons.
Nov 04, 2010 | Audio Players & Recorders
I think i put my camera in movie mode and now cannot take any pictures, how do i reset my camera to take pictures
All you need to do is rotate the shooting mode selector dial on top of the camera to an appropriate shooting mode.
Try putting it on the Green color "Auto" and you will be good to go!
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this free solution.
Sep 30, 2010 | Canon PowerShot S1 IS Digital Camera
My F100 will only fire in the self timer mode. Solution?
Check the selector in the front lower right of the camera. Move it to M then S, then C, then back to S. Next: you need to adjust the setting from self timer back to normal, press the mode button and check the icon select from self timer to normal shooting mode.
Apr 27, 2010 | Nikon F100 35mm SLR Camera
Cant get it off movie mode whats wrong
You can open the case (take the six small screws out two on the bottom and two on each side) Both the front and back will come off you may have to work it a little to get them apart. Look at the back and you will see a three position switch if it is to the far right move the switch to the center position and turn the camera on see if you are out of movie mode if you are verify that the plastic switch cover on the back of the case is not broken (it may just have been misaligned. If after moving the switch and you are still in movie mode you have a component problem and you will most likely need to send it in or buy a new camera. Hope this helped
Jul 22, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
I can't get it off movie mode
You can open the case (take the six small screws out two on the bottom and two on each side) Both the front and back will come off you may have to work it a little to get them apart. Look at the back and you will see a three position switch if it is to the far right move the switch to the center position and turn the camera on see if you are out of movie mode if you are verify that the plastic switch cover on the back of the case is not broken (it may just have been misaligned. If after moving the switch and you are still in movie mode you have a component problem and you will most likely need to send it in or buy a new camera. Hope this helped.
Jul 11, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
A630 clicks and wont take picture. Stays in preview mode.
Do you mean you are expecting it to show the photo that you just took for a few seconds before it goes back to preview mode? There's a menu setting which I think is called "Picture Review" and you can set it for something like 0, 2 seconds, 5 seconds, something like that.
I hope that was it.
-Vince
Oct 01, 2008 | Canon PowerShot A630 Digital Camera
SCN Mode on Canon A560
It confused me too. Just go to SCN and hit the function.Set button (the little round button). It brings up a menu and you can switch left or right with the menu controls.
May 25, 2008 | Canon PowerShot A560 Digital Camera
A345 stuck in movie mode
you need to open the camera caseing a small amount. As you put the case back make sure the switch is in the movie position so it will engage the switch inside on the circuit board. Looks like the switch has been knocked off the control inside.If you have been moveing the switch back and forward you may have broken it.
Dec 27, 2006 | Fuji FinePix A345 Digital Camera
Canon PowerShot SD1400 IS  IXUS 130 Digital Camera Logo
12 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
