Question about Crate SPA1600 Power Amplifier - SPA Series Car Audio Amplifier
Crate BT50 Bass amp cutting out with high input.
My Crate BT50 cuts out when I add distortion or drive it over a certain level, any ideas?
  • 1 more comment
  • fadz Feb 27, 2008
    hi, i have 2 kicker L7 15" subs and a directed 2400 monoblock amplifier also a power acoustik 3 farad capacitor. eveything is wired and connectected perfectly with 0 gauge wires but when i seem to put the volume up or increase the bass with my bass controller it starts cutting out both my subs and amp, this is recently as i never had problem like this before. can anyone tell me what the problem might be? my amp gain is to the max but i'v tested it with it down and same problems still occur.
  • Anonymous Mar 03, 2008
    My Crate BT 50 is less than 3 months old, used only for low level practice until last night's gig. Under lower power for tune-up, it cut from low-to-high levels repeatedly. Still does it at home now at all levels. It is unuseable as it is.
  • spurg1 Mar 27, 2008
    I had the same problem with a brand new BT50(distortion channel only). Took it back for an exchange and had the same problem with the replacement. I tried all combinations of guitars, cords and settings but the problem was always there. Last week i bought a new BT220 and it has EXACTLY the same problem. I noticed that MUSIC123 has completely quit selling Crate bass amps. Any ideas on what causes this would be appreciated. Thanks.
Sometimes an amplifier's preamp can't handle certain signals/frequencies at a high gain, so they cut out. Bass guitars are especially prone to giving such a strong signal.
I bought an older, nonworking bass amp recently and fixed it just to find it had the same problem. Best solution is to put a low ohm resistor at the amps input, but if you turn your guitar down to half volume it'll have the same effect: should prevent it from cutting out.
Posted on May 20, 2008
Towing camper trailer was told by mechanics not to take it out of 5th gear and towe around 100km/hr is the correct .
the towing procedures will, be in the user manual
depending on the trailer weight( less than 1 ton) it is permissible to tow in over drive and for a trailer without load levelling ( stabilizer bars ) 100 klms would be an ideal speed
5th gear is a direct drive gear ( input and output shaft connected as one) and the idea of staying in 5th gear reduces the load on the gears and bearings
Apr 10, 2016 | 2010 Mazda BT50 XL
250 kg is sitting on a horizontal surface. Hence, the ground or the horizontal surface is exerting 250 * 9.8 = 2450 N to support the crate. Now, coeff is 750/2450 = 0.306 . The force you have to exert to move crate depends on how heavy the crate is. If crate is heavy you will end up exerting more force. The ratio of the forces provide the coeff of friction.
Dec 09, 2013 | Lands Phones
Distortion stoped working on my amp
Hi there. Sounds like the distortion foot switch is stuck. Try a shot of WD-40 where the button goes into the switch and then click it on and off a bunch of times.
May 28, 2009 | Music
Plugging line level into my crate TX15. all inputs sound distort
guitar amps are all set to a low Z resistance configuration. wich are made for guitar only. make sure you are using the right cables.
you need sheilded guitar cable not unshielded speaker cable in many cases these cables look exactly the same. look at your cable look for the words speaker or instrument. you need the instrument cable. if you still have that problem. then you may just not be satisfied with the quality of the amp it self.
Feb 26, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Intermittent shorts in a Crate Limo TX50DE Guitar
turn that ****** on and get a can of freeze spray. coming and going type issues is usually related to a failing electrolytic capacitor. there may also be a bad mosfet, rectifier, diode, etc. i would be suspect to caps. schematics probably only available thru crate and you have to pay a couple bucks, but trust me its worth the couple bucks spent and having it on its way than wasting hours online not getting anywhere. by the way i checked my sources and came up with nada.
Feb 20, 2009 | Crate SPA1600 Power Amplifier - SPA Series...
No sound out of the Amplifier.
hello if you not even heard a low buzz en the speakers with all volume up is probably burned take it to rapier shop for a estimated saludos
Jan 08, 2009 | Audio Players & Recorders
Subsidy password for motorola BT50 phone
who can give me this subsidy code for motorola bt50! please send me your idea to
Jul 22, 2008 | Cell Phones
Playing songs at certain volume
Several things can effect the quality of your files. 1. Check your headphones by comparing them with others. 2. The file quality may be too low, you can test that by getting a higher quality MP3 file and comparing the two. 3. If you are creating the MP3 files yourself, be sure to watch the sound recording level. Allowing it to stay in the red can produce distortion while recording ay too low of a level can result in low voulume as well as possible distortions. If none of these correct the issue, you may need to replace the player.
Jun 18, 2007 | iLO (2 GB) MP3 Player
Open Questions:
Crate SPA1600 Power Amplifier - SPA Series Car Audio Amplifier Logo
2,365 people viewed this question
Top Crate Car Audio & Video Experts
xxxxxx xxx
Are you a Crate Car Audio and Video Expert? Answer questions, earn points and help others
