Question about Hayward 1.5 Hp Northstar High Performance Pump
My hayward pool pump started making a humming sound then shuts off. when I try to start the pump it starts humming then trips the breaker and then again shuts off
  • 93 Answers
Check impeller by turning shaft with pliers sounds as if its stuck do this while of and try to restart
Posted on Jun 18, 2009
My hayward pool pump not working,forget to close the air vent before pump started and is water allover the pump,what to do?
Water sprayed on the pump occasionally shouldn't hurt it but it might cause a ground fault circuit interupter (GFCI) to trip. If you turn on the pump and literally nothing happens then most likely the the GFCI has tripped. If it hums then this is a different issue. If you have a volt meter you can open the timer box and check whether power is available to the timer. If no power is available in the timer then it confirms that the pump is probably ok. Checking your circuit breaker panel for a tripped breaker or finding a tripped GFCI then either one can be reset and your pump will probably run without a problem.
I hope this helps.
Sep 16, 2011 | Hayward Tristar Pool Pump 1 Hp for In...
My hayward 1hp super pump hums when i turn it on but doesn't turn or pump it eventually trips the circuit breaker inside
Inside pump is a difram , it most likely is stuck, some times if you shut off pump, turn back on a few times it might release itself, but most likely needs to be replaced. Let me know, mike from fixya.com
Jun 08, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
Turn breaker on to hayward pump 1 1/2 hp model C48L2N134B1 just heard a humming noise and shut off
DIRTY START SWITCH OR AND COULD BE THE START CAPACITOR OR RUN CAPACITOR,. RUN CAPACITOR IS ON TOP OF THE MOTOR. I WOULD SUGGEST YOU TAKE THE BOLTS OUT AS PICTURED AND BRING IT TO YOUR LOCAL POOL PUMP REPAIR GUY WITH FREE TESTING.. SEARCH YOUR AREA FOR HIM ..JAY LONGWOOD FLORIDA
May 22, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
Turning off
the pump motor has a short in it, most likely to be in a field coil it may be repaired but its likely to be far cheeper to replace the motor and there should be a way to turn it off,,,the brakers will trip every time the motor starts to humm becouse the motor is pulling far to many amps for that trip so to save a "fire!" it trips out,,,,do yourself a big faver and have it looked at fast
Jun 05, 2010 | Hayward 1.5hp Pool Pump Motor Motor A O...
Hayward flo pump motor repair
What exactly is wrong with your pool pump? If it won't start at all, check for improper or loose connections, blown fuses or tripped breakers, and open your switches and replays. Manually check the rotation of your motor shaft. Make sure that there is free movement and no obstructions. If the motor hums, but won't start, check for obstructions and check the Centrifugal switch to see if it is stuck in the open position. If you have low flow, check pool pumps for clogged or restricted strainer/suction line and discharge line of filter. You could also have an air leak in suction (bubbles issuing from return fittings). Low voltage could cause loss of suction. Check for plugged or restricted impeller.
Jun 02, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
Haywood Max-Flo Pump (self priming)for indoor inground pool 3/4 HP ... model C48J2N131A -- yesterday turned off master breaker switch to everything in the pool area (including power to pump) so that I...
The motor may have blown the start capacitor. It is the black cylinder about 1-1/2" dia x 2-1/2" long. Look at the end with the wires for a small hole. Is it blackened or have a hole blown thru? If so replace it. Otherwise have a local electric motor repair shop look at it for possible repair or replacement.
Sep 06, 2009 | Hayward Pool Products Hayward Max-Flo 1...
Hayward Super Pump not turning on
it sounds like your pump is stack it could
bee that something is stack in the pump,
try somehow to turn the motor to see what is binding
get access thrue the pump.
G
May 18, 2009 | Hayward Super Pump 1 1/2 - Hp for In...
Hayward 1.5 Hp Northstar High Performance Pump Logo
2,016 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
