Question about Shuttle Computer slim xh61v bb 65w i3 i5 i7 no cpu no ram no hdd no dvdrw blk 3yr - shu
Xh61v System powers up then down after 30 seconds, then powers on again and so on. No monitor signal, so disconnected.
Why is my laptop screen black during startup?
I recommend you to connect an external monitor and check if there is display on it. Press 'Windows' + 'P' on the key board to get display on the external monitor.
I also suggest you to run diagnostics on display. To test the display shut the system down, next press and hold the letter 'D' on the keyboard and press the power button. This will initiate diagnostics on the display. Please check if the colors are displayed across the screen without a problem.
You may also try this step that is shut the system down, remove the battery and disconnect the ac adapter, press and hold the power button for 20 to 30 seconds. Now connect only the ac adapter and wait for 30 seconds , press and hold the Fn key on the keyboard and power on the system. This will run diagnostics on the hardware components and also the display.
check also:
Please let me know if there is any light on the keys shows below:
5557.led-status.png-
if any of these are flashing in a sequence
please reply back with results
Jun 08, 2014 | Dell Latitude E5500 Laptop
HP w2207 no vga input signal, no dvi input signal monitor goes to sleep
There is no signal coming from your PC.
excuse some of the solutions as sounding dumb, but we have to explore all possibilities.
Check the power cable going into the computer
Check the power input disconnect switch on the back of the power supply and make sure it is on
If the pc is plugged into a power bar, make sure it is turned on and the breaker isn't tripped
press power on the PC and make sure the lights are coming on.
now for the solutions that may actually help.
disconnect the power from the PC
if the video is on a card, remove and re-seat the video card
hook the power back up, connect the monitor and try again.
the CMOS on the computer may need to be reset.
I hate totally clearing the CMOS, so what I usually do is remove 1 stick of ram and power up. If the system is alive again, power down, put the RAM back in and power back up.
If that doesn't work, turn the system off, put the CMOS jumper to the CLEAR position for 15 seconds, put it back to the Normal position and then power back up.
Basically, if the monitor works on your friends system but not on yours, the the problem is your system, not the monitor (assuming it isn't working fine til it gets into windows...if that's the problem, you have a driver or configuration problem)
Jun 10, 2012 | HP Computers & Internet
My gateway computer power light blinks and moniter says no signal.turn it off held then power button on for 30 seconds.then turned it back on.same as before.
I don't think this has anything to do with the monitor since it is showing "no signal". this is an indication that the monitor is working.
Problem is from the connection between the computer and the monitor or from the computer itself.
Check the VGA cable and make sure it is firmly fixed into the computer and monitor.
Open the computer case, disconnect the keyboard, mouse, and every other thing apart from the VGA cord, then try again.
If there is still no signal, turn computer off again, remove it's power cord, then remove the system Ram, clean it and fix it back in. Then make sure the VGA card is well fixed into the mother board. After that, connect only he VGA cord and try again.
If non of the above seems to work, connect the computer to another monitor, and connect the monitor to another computer in other to confirm which is having a fault so that we can focus on it.
Keep me posted.
Good luck.
Jul 11, 2011 | Smart Modular SV3170A
My acer 19" monitor has no signal what should i do?
  1. check whether the signal cable properly connected to the vga port or not ?
2.listen the single beep from PC
3.try monitor on another PC . if persists , then the fault lies in the monitor . if not then the fault is in the CPU
thank you.
4.if no beep from CPU then disconnect RAM . listen contineus beep . if heard , then the RAM is faulty , replace it .
Jul 23, 2010 | Acer AL1916W 19" LCD Monitor
GRAY BOX SAYS NO SIGNAL AND IT GOES ON AND OFF
The monitor is not getting a video signal from the computer (if it is connected to a computer)
Try the following steps first:
1 Turn off power and disconnect power cables from the computer
2 Press and hold the power button for 30 seconds
3 Reconnect power cables and try to turn it on.
If everything remains same, the next step will be to re-seat memory modules.
Mar 07, 2010 | Acer V193w LCD Monitor
My emachine T1742 desktop will not turn on. When plugged in the power supply's fan turns on, cpu fan doesnt start, both hdd/power led's flicker and pressing power button doesnt power on/off system.
Disconnect all the devices from the computer(tower) including keyboard, mouse, monitor(everything)..even the power cable
Now keep on holding down the power button on the computer tower for 15-30 seconds..
Now release the power button, plug in the power cable, monitor, keyboard, mouse and turn on the computer...
If it works, great!!!
Otherwise, take it for repair..
Dec 03, 2009 | E-Machines eMachines Desktop PC
Dell optiplex gx150 power button just flashes - help?
System seems to be in hibernate or standby mode and frozen in that state. Hold dosn power button for 5 seconds or until all signs of life shut down. Wait about 30 second and power up the system.
Jul 25, 2009 | Dell Optiplex GX270
COMPUTER WON,T YURN ON
first of all,is your power cable properly connected to your system unit.if it is not,connect it properly and turn the system unit on again
secondly,make sure your signal cable from the monitor to the system unit is properly connected
after following these instructions,reboot your computer again.
thank you for consulting fixya with your problems
Feb 14, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
X191w blank screen after 2 seconds
Just got off the phone with Acer Suppport. This was after I sent an email to them, that suggested that I call. 8-/ annoying. So the guy on the phone says there is one thing that we can do before sending it in. Unplug it completely for the wall and computer. Hold the on/off button in for 30 secs. reconnect power and the computer. It worked for me
Oct 07, 2008 | Acer X191WSD Monitor
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
Shuttle Computer slim xh61v bb 65w i3 i5 i7 no cpu no ram no hdd no dvdrw blk 3yr - shu Logo
43 people viewed this question
Top Shuttle Computer Computers & Internet Experts
David Payne
David Payne
Are you a Shuttle Computer Computer and Internet Expert? Answer questions, earn points and help others
