Question about Husqvarna Sewing Machines
Squeaking husqvarna 445
Ow to oil
    Problem Solver:
  • 19 Answers
You do not oil Viking machines.
Posted on Feb 08, 2015
How to remove the covers
If it is a computerized machine, the covers are not meant to be removed as the computer components could be easily damaged.
Oct 08, 2016 | Husqvarna Interlude 445 Sewing Machine
It squeaks, can I oil it, and if so where
I wouldn't. Take it in for a Maintenance; there are a dozen spots it could be and most can't be got at.
Mar 25, 2015 | Sewing Machines
How do I change e presser foot on my Husqvarna Interlude 445?
You pull it toward you to get the old one off. Then you push the new one into the slit in the white plastic ankle.
Sep 15, 2014 | Husqvarna Sewing Machines
Why is my handwheel hard to turn and making a squeaky noise?
Sounds like possible thread in the gears, or the wrong oil might have been used to oil the machine. Sewing machine oil (clear oil) should be used for oiling the machine. I use an oil called Tri-Flow Lubricant which is available at your local bicycle repair shop.
May 28, 2014 | Husqvarna Huskylock Computerized 910
White model 534 serger
Your serger most likely need to be oiled. It is important that you keep your serger clean and oiled. More so than your sewing machine. If this is a new squeak, you can try to oil the area that it is coming from yourself if you can get access to it. If it is not a new squeak it is possibly coming from the motor or the belt and then I wouldn't suggest to oil those parts. If you can't get to where the squeak is at bring it to a repair person and they should be able to take care of it.
Sep 13, 2013 | Sewing Machines
Husqvarna making squeaking noise
try changing the needle
try a different bobbin--make sure the bobbin is turned the right way
in the bobbin case
also try a different thread
make sure the top has not come off the thread take up lever
also the machine may have a timing problem and need to be
serviced
Dec 08, 2012 | Sewing Machines
I have a interlude 445. do I need to take it in and have it oiled? Does it use up its oil over time and use?
No. That particular machine never needs oiling. That is one of the great things about a Husqvarna Vik sewing machine.
Feb 17, 2011 | Husqvarna Interlude 445 Sewing Machine
My embroidery unit on the Rose squeaks loudly when in use. Can I oil it? Does it need servicing?
Typically does not need oiling but if you do, use Tri-Flow oil available from most bicycle shops. But it would highly recommend you take it for service at an authorized Husqvarna Viking service technician. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Nov 18, 2009 | Husqvarna Rose
Husqvarna 51 chainsaw will barely run, magnito and carberator ok
Probably need to re-adjust the carburetor jets. They are very small screws in the base of the carburetor. They will be labeled with an "H" and an "L" . Set the low speed first by turning it in slowly until the rpm drops slightly then start turning it outward untill the engine idles smoothly. At that point you can also adjust idle speed. Then you need to be careful here but you need to hold the throttle wide open at the same time adjusting the high speed jet. Turn it in until the rpm drops then slowly turn it out. The rpm will keep increasing. Once you get to a point where it is max'ed out then screw the jet back in one half a turn. Changes in altitude like using your chainsaw in town versus going to the mountains for firewood can sometimes make it necessary to adjust the fuel/air ratio.
Feb 18, 2009 | Husqvarna Husky 165
Squeaking huskylock 905
The internal cams need lithium grease. You might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Jan 10, 2008 | Husqvarna Huskylock Computerized 910
Sewing Machines Logo
48 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
