Question about Northern Tool Lawn Mower Battery 12 Volt, Group U1r
Dura start U1-2 lawn mower battery
What is the voltage? I have a dead battery & need to charge or jump it to get my mower going.
Riding mower won't start & makes clicking sound when I turn key over
MAKE SURE BATTERY IS CHARGED IF IS THEN JUMP LAWN MOWER AT STARTER IF STARTS BAD BATTERY ARE STARTER RELAY COST 60.00 I STILL THINK YOUR BATTERY IS BAD OR DEAD NOT ENOUGH CHARGE IN IT
Sep 01, 2014 | Garden
I have a riding yard machine mower. Had trouble starting without jumping the battery. Bought a new battery & it started right up. Mowed the front & side of the yard & shut it off to open my...
Now you are describing 2 different problems... If you have nothing I doubt the battery is dead but would check for a safety switch problem. If it clicks or turns over slowly then we need to be looking at a bad connection or other issues... Please describe your problem better to let us help you solve it
Nov 13, 2013 | Yard Machines 155 Torque Briggs Stratton...
I have a craftsman with a kohler magnum 18hp. If i put a battery charger on my battery it dont charge i can turn the key and it wont roll over. If i jump my lawn mower and it running i can turn the key all...
Hi, if your battery wont charge you will need to replace it and when you do you need to check that the mower is charging by checking the battery voltage with a multimeter while the mower is running. It should be around 14 volts. Regards Phil.
Sep 06, 2012 | Craftsman Garden
My Craftsman 16 hp and 42 battery not charging is it normal?
get mower started and check the charging voltage at battery. it should be at least 13.5 at battery.check cables to battery and the inline charging fuse, its located somewhere in charging system.if its charging, but battery is still dead. it could be a bad battery. or alternator. . Examine the lawn mower electrical system by starting the lawn mower up, and then removing the battery. If the lawn mower turns off after the battery is disconnected, the lawn mower electrical system is the culprit.
its a good possibility that the battery is bad if it has been in use for 4-5 years.
check the fuses first. good-day !
Oct 02, 2011 | Garden
The battery in my JD lawn tractor was dead; it started and mowed several times with a jump start but eventually only the tractor would run while the mower would not engage. With a new battery installed,...
I suspect that the alternator/generator has gone bad, preventing the battery from chargine, or generating enough voltage to keep the electric pto on your mower engaged.
I think that it is located on the engine beneath the flywheel.
I hope this helps you.
Aug 03, 2011 | John Deere Garden
Dead battery
The blade clutch is electric. A bad battery might be interfering with the clutches engagement. You should make sure you have good contacts on the battery at both ends. Replace any battery cables that are excessively corroded. If the battery had removeable caps for filling you might want to check the electrolyte levels and top them off with some distilled water. You can also jump start your mower and check the voltage while running with the blade off. If you dont see voltage going up while the engine is running you probably have battery and charging system issues. The battery should have at least 12 volts with the mower off and 13-15 volts with the engine on.
A bad charging system would require repairs on the motor and should be handled by a local repair shop. At least you can rule out the diy stuff first though right?
Good luck and be caeful. Wear eye protection whenever working around batteries with jumper cables. Weak batteries give off explosive gases. Always connect the cables to the bad battery first and then the good battery to avoid sparking near the bad battery.
Jul 25, 2010 | Husqvarna 54'' Package Deal Zero Turn...
Tractor wont start unless I jump it
How old is the battery? When you get it started put a digital volt meter across the battery terminals and with the throttle about 1/2 open check the voltage. If should be over 13 volts DC if your charging system is working ok. If it is over 13 volts your battery has probably just given up. Lawn mower batteries are only good for 2-3 years. A trickle charger can extend the life if used.
I hope this helps.
Jun 17, 2010 | Yard Machines 155 Torque Briggs Stratton...
Batt dead jump start does not seem to charge
Sounds like a dead or shorted cell battery. Charging system is probably working but is showing overcharge since it is trying to charge a brick. Replace the battery and all should be well.
Jun 02, 2010 | Toro Lawn Mower With Toro Power Tools
Troy built lawn mower does not go on
you need to be sure the battery you are jumping is fully charged to start with.
Apr 06, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Northern Tool Lawn Mower Battery 12 Volt, Group U1r Logo
166 people viewed this question
Top Northern Tool Garden Experts
Vernon Taylor
jeff chenault
jeff chenault
Are you a Northern Tool Garden Expert? Answer questions, earn points and help others
