Question about Acer Aspire 3003LCi Notebook
Battery When I plug my battery, the system would stop responding (freezes). When this happens I must remove the battery and disconnect power, then restart without the battery.
  • Anonymous Nov 03, 2007
    I had the same problem. The computer froze or was extremely slow, with keyboard and mouse only working intermittently. The battery was bad. So, either use it plugged in or pony up for an expensive new battery. Leaving laptops plugged in will shorten battery life, as my teenager found.
  • EICSI Nov 09, 2007
    I am yet to try the suggestions, but the information most helpful. Thanks so much.
  • 117 Answers
Check your battery and apply your processor heat sink paste
Posted on Nov 07, 2007
D tablet pc charged but not responding at all says if it freezes or crashes put thin pin in reset but does not tell you where this is ???
Disconnect all peripheral devices, Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain all residual power and restore default startup settings. Then reconnect the AC power adapter (but do not insert the battery), press the Power button, look for glowing Light Emitting Diodes (LEDs) near the caps lock and num lock keys, and listen for sounds of a fan or other moving parts turning.
Jan 05, 2014 | HP Pavilion dv1000 Notebook
I have an older Uniden PowerMax 5.8 and the handsets are old and one is held together with tape. The second hand set was rained on yesterday. It was sorta working but I worried i would short it out if I...
Hello, Terrie.
Sorry for the delay in responding - time zone difference.
First, let's see if we can fix your handset (from Uniden):
1. Remove the battery cover and leave it off for ventilation.
2. Remove the battery pack by disconnecting.
3. Leave the battery cover off and the battery pack disconnected for at least 3 days.
4. Once completely dry, reconnect the battery pack and the battery cover.
5. Recharge the handsset's battery pack for 20 hours in the base unit before using the phone. IMPORTANT: You must unplug the telephone line while recharging the battery pack
to avoid charge interruption.
I believe there is a way to export your phone book to another handset, but not without reviving your original phone. Unlike a cell phone, there is no memory card to remove and transfer.
Let me know what happens.
Hope this helps.
Oct 06, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
Cant find horn
the horn is located under the battery, either remove the battery and tray or remove the inner fender well. some people have claimed that when they disconnect the battery they now have a problem resetting things or the auto locks stopped working??? I have had my battery disconnected several times and nothing like that has happened, knock on wood maybe? The fender well is easy to remove without disconnecting power so do that to be safe.
Jan 27, 2011 | 1998 Ford Explorer
I have recharged a low battery on two different occassions and both times all radio info was cleared. Whu Happen? Car being 2001 Hyundai Sonata.
Hi Duffygolfer,
I understand your problem that your car audio FM settings were getting deleted automatically.
For you information, please understand that most of the car audio systems will retain the settings stored to in it will be retained in the audio system memory by making use of the battery power even when the car is switched off and key is removed.
So in case if the car battery is removed or gone into low battery, then there will be disconnection in the power sent to the car audio system for retaining the user customizations like FM frequency, settings, etc.
As you have said that your car battery ran out of power twice, thats the exact reason for why all your car audio player FM station settings has been wiped out.
I hope you understand the reason behind your problem and this does not denote any problem with your car audio device.
Thanks
Mar 30, 2010 | Car Audio & Video
Panasonic CF-30: While plugged into a/c the
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
For me, it looks like the Canon LiDE 100 USB powered flat scanner was drawing extra power than your laptop's power adapter could handle properly. As time passes, this might have caused some damage to either the system, the A/C adapter or both. Rightnow, your laptop's adapter's output might be no longer capable of supplying enough power to charge the battery & operate the laptop simultaneously. Please try a replacement adapter & check if it resolves your problem.
Dec 28, 2009 | Panasonic Toughbook CF-30 Notebook
Samsung Tocco touch screen freezes
i've got the same problem with you. my phone wont respond to my commands everytime i charge my phone. sometimes it responds but would respond very slowly as if the interface is lagging. every now and then the phone would freeze and wont respond and wont turn off and only way to turn it off is by removing the battery. anyone else having similar problem? how to fix this?
Aug 04, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
No response
First follow procedure to try to reset the power.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
May 23, 2009 | Acer Computers & Internet
The screen is black,
Sometimes the PSP's will freeze for one reason or another. In most cases the psp will turn off within a minute and then restart itself. If not disconnect any power supply and remove the battery for a moment to manually reset it. Hopefully you saved recently.
Feb 21, 2009 | Namco...
Keyboard not responding on a hp pavilion dv 2000
remove all power from your comp. without shutting down. remove external power first. then remove your battery. the drivers are overloaded and confused. this worked for me.
Feb 06, 2008 | Computers & Internet
Sony NW-E107: Player stops responding. Possible memory failure
I have the same problem. Sometimes mine just turns off, then back on plays for 1-2 seconds then turns off/on again, and does it about 4-5 times before freezing.
Nov 09, 2006 | Sony NW-E107 MP3 Player
Acer Aspire 3003LCi Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
