Question about Dyson DC25 Vacuum
DC25 brush head intermittent--bad connections at brush head connection
Roller bar will not spin on dc25 animal
If the brush bar motor is running try putting on a new belt. If the motor is not running it may be the main switch, the switch that activates when you recline the handle, the motor itself or a loose wire or connector somewhere. Check the connection between the vacuum and the power head. If power isn't transferred properly the motor will not run.
You have to closely check all these areas to find the problem.
Mar 05, 2017 | Dyson DC25 Animal Bagless Upright Vacuum
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    Why won't the brush head on my DC25 turn?
    If the brush bar motor isn't turning it could be the switch or the motor, if it is turning you may need. To replace the belt
    Aug 02, 2014 | Dyson DC25 Animal Upright Ball Bagless...
    Dyson DC25 Broken Brush Bar Connector
    Hi Alex, it's Jack at Dyson.
    I'm sorry to hear you're having difficulty with your DC25. If the drive spindle of your machine has broken in use, you would need to replace the cleaner head assembly.
    Please get in touch with us directly, as our experts will be able to take some further details to confirm if we're able to replace this for you under the terms of our 5-year warranty. You can reach us by emailing askdysonUS@dyson.com
    Best wishes,
    Jack
    Dyson Online Customer Support
    www.dyson.com
    May 19, 2013 | Dyson DC15 All Floors - The Ball Bagless...
    Brush stopped working, cleaned belt, can not find reset button and does it have a belt?
    Hi Brenda,
    Your DC25 is equipped with a sensor which shuts off the brush bar if something jams it. Once you've checked the cleaner head for obstructions, and removed any threads or hair from around the brush bar, you should be able to reset the machine.
    The brush bar will not rotate when the machine is standing upright, so make sure you recline your DC25 into the vacuuming position before testing it.
    Please note, the sensor will protect the belt from damage, so it is not necessary to disassemble the cleaner head as shown in the video posted by small6363. Dismantling the cleaner head to this extent will also void our 5-year guarantee on this machine.
    If you'd like any further assistance or advice, please give our customer Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
    Best wishes,
    Jack
    http://www.dyson.com
    Apr 25, 2012 | Dyson DC25 Animal Bagless Upright Vacuum
    My daughter has a Dyson D25 ball vacuum cleaner that the brushes does not turn on it. I have cleaned the head, motor and belt. Still does not work. I tried to check the voltage on the head connection...
    Sorry to hear about the problem with your daughter's DC25. To check everything is correct with the machine, please follow these simple steps:
    http://www.dyson.com/support/help.asp?article=1156&product=DC25-ALLFLOORS
    If you've run through these checks and are still having difficulties, please get in touch with us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to run through some troubleshooting over the phone, and provide the assistance you need.
    Kind regards,
    Jack
    Dyson Customer Service
    Jul 23, 2011 | Dyson DC25 All Floors Bagless Upright...
    When I turn my Dyson ball DC25 vacuum on and engage the brush it makes a screeching noise. I have cleaned the brush and the filters were cleaned a week ago and are in correctly.
    Check if the belt still is connected and freely rotating the brush. Dyson vacuum belts are not replaceable.If the belt is going bad, the clutch assembly has to be replaced
    Apr 23, 2011 | Dyson Vacuums
    Dyson DC25 Vacuum Logo
    54 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Nick Olsen
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
