Question about Singer 57815 Mechanical Sewing Machine
Raise feed dogs on singer 57815 - Singer 57815 Mechanical Sewing Machine
  • 43 Answers
SOURCE: How do I raise and lower the feed dog on my singer
On your Singer, you don't actually raise / lower the feed dog. Instead you attach a "darning plate" (which should have come with the machine) which covers the feed dogs so they do not come in contact with the fabric. See a page from the owner's manual using this link within my web site: http://www.sewvac1.com/Singer3080_Feed_Drop.pdf
Posted on May 06, 2009
  • 139 Answers
SOURCE: Need user manual for the Singer 57815
You can order parts through the Singer parts centers listed on this page:
http://www.singerco.com/support/replacement_parts_ssc_list.html
Posted on Apr 13, 2010
  • 3 Answers
SOURCE: I have a singer 4830C. Is it possible to lower the
No, but it does come with a cover for them so you may do free-motion sewing.
Posted on Nov 12, 2010
  • 1456 Answers
SOURCE: feed dogs will not raise, I have lifted the
Hello
First, lift the presser foot; next, push the feed dog lever to the raised position; finally, turn the handwheel towards you until you hear the feed dogs snap into place
If it doesn't, you will have to run a maintenance check on your feed dogs,
Unplug the machine and examine the feed dogs. The newer machines have metal feed dogs, but older models may have rubber ones, which often need replacing. Examine the feed dogs and check for damage.
Remove the throat plate, which is the covering over the feed dogs, and clean it with a soft cloth. Use a small soft brush to clean the feed dogs. Make sure to remove all lint and thread from the grooves of the teeth. Some machines have an adjustment that lowers the feed dogs for specific sewing procedures. They should be in the raised position for better viewing during the cleaning process.
Clean the area around the feed dogs with a soft brush. Compressed air is a good choice to use in the small tight areas.
Wipe down all areas with a clean, lint free cloth before replacing the throat plate.
Prepare to clean the feed dogs and all other areas that lint may accumulate on, after every project. Your sewing machine will last longer and need fewer repairs if kept clean and lint free.
Always unplug the sewing machine before any type of maintenance or cleaning.
Never use a sharp tool when cleaning the feed dogs as this may cause damage to the sewing machine.
Posted on Apr 16, 2011
Zenqi
  • 208 Answers
SOURCE: I have a Singer Stylist 513 & I cannot get the feed dogs raised.
The model 513 Singer has two gears which operate the feeding mechanism. If one of these gears is broken, the machine will run except the feed dogs will not move. This is a very common problem with this model.
Posted on Oct 07, 2011
Singer touch tronic 2000 feed dog will not advance fabric
Confirm the feed dogs are raised. Make sure the feed dog teeth, area under the needle plate and the bobbin area are clean of any debris, thread, or buildup. Some machines also have a presser foot pressure adjustment that increases the pressure the presser foot applies to the feed dogs. The feed dogs could be worn (never run the sewing machine without fabric between the presser foot & feed dogs).
https://www.manualslib.com/manual/508740/Singer-Athena-2000.html
Or, the machine has not had a thorough cleaning and oiling recently and the feed dogs are sticking from old oil.
Wheel on right side that controls the needle up and down is very tight...
Jul 30, 2017 | Singer Sewing Machines
6235 singer ! How do I raise feed dogs ???
According to the manual, there is an accessory that covers the feed dogs. (Shown as an accessory on page 4.) So the feed dogs should not raise or lower other then during normal sewing action of moving the fabric.
Singer 6235 User Manual Page 24
Singer 6235 User Manual Page 6
Dec 27, 2016 | Singer Sewing Machines
Feed dog on singer m756 won't pop up
If this is a combo embroidery and sewing machine, the feed dogs have a switch to raise or lower them. If this is just a sewing machine, your feed dog linkage may be broken.
Jul 15, 2014 | Singer Sewing Machines
Can not locate feed dog switch for model6233
the question is under the singer sewing machine category, so I look up a manual for a singer sewing machine model 6233, the feed dog information should be in there. http://www.singerco.com/uploads/download/1314_6233.pdf
Jan 25, 2014 | Singer Sewing Machines
Singer 758 model and the material is not feeding through the machine. Needle is only going up and down in one spot.
here is a link for a free manual, check to see if the feed dog lever is up in the sewing position, if the feed dog lever is down then try to raise it up. if it will not raise then the machine needs to be check to see what's wrong with the feed dog.
http://www.singerco.com/uploads/download/6dc4cd61b0c61a5fc13e60785f01d29199328059.pdf
Nov 18, 2013 | Singer Sewing Machines
I have a singer 543 the feed dogs won't move.
I suggest getting out your manual and looking up lower and raising the feed dogs. When the feed dogs are lowered they don't move. You could have lowered them without realising it.
Mar 18, 2013 | Sewing Machines
Can't raise the feed dog on Quantum XL 1000
If I remember correctly you have to raise the feed dog then turn the fly wheel 1 revolution to lock them in place
Feb 07, 2013 | Singer Quantum XL-1000 Computerized Sewing...
Singer Sewing Machine model #2638 Does not feed fabric
Here is a link to page 22 of the manual. It shows you where to flip the lever to raise the feed dogs. If your feed dogs are not grabbing fabric your feed dogs are lowered.
https://www.manualslib.com/manual/1050311/Singer-2638.html?page=23#manual
Sep 20, 2012 | Sewing Machines
How do I raise and lower the feed dog on my singer 8280??
May 06, 2009 | Singer 8280 Mechanical Sewing Machine
Singer 57815 Mechanical Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
