Question about GE JVM2050 Microwave Oven
Microwave not heating
Display and other controls, turntable, vent all still work. replaced the most common fuse already. may need new magnetron
AlmostBob
  • 550 Answers
SOURCE: fuse keeps blowing.
couple questions -
what else is on the circuit,
and what current does the oven need
there are whirlpool over-range models with
1200watts of microwave,
1500watts of convection power, a
60watt bulb and a
375watt fan
over 15amps -20amp circuit needed
if you inadvertantly replaced a higher current fuse with a 15amp fuse, it will blow every time.
the install guide http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/8206589.pdf reccommends 20amp
not a solution, something to check,
Posted on Oct 14, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave won't heat, and turntable doesn't turn
All the parts you mention are very inexpensive, but yours does not have a triac.
It could be the cook relay, but it's more likely to be a switch.
Looking at the schematic, it's probably a bad primary interlock (upper door switch) or maybe its mount is bad.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you have a broken mount, it's usually more economical and safer to just add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
Here are some helpful links:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or elsewhere, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Jan 23, 2009
  • 178 Answers
SOURCE: GE Microwave JE2160 does not heat
Does it make any noises that it didn't before it failed?? It could be a bad secondary interlock switch, cook relay on the PCB, HV circuit problem or bad magnetron. You need an ohm meter to troubleshoot. If you take the cover off, you MUST short across the High Voltage Capacitor terminals to discharge any possible residual charge to prevent shock hazard.
Posted on Sep 11, 2009
  • 72 Answers
SOURCE: GE Spacemaker Microwave
you have a bad door switch, probably the bottom one
Posted on Feb 05, 2010
Testimonial: "Quick and to the point."
beltronic205
  • 1461 Answers
SOURCE: GE Spacemaker Microwave is not heating, replaced
Check thermal fuse cut out gone..
Posted on Apr 06, 2010
My kitchenaid microwave will not heat in microwave mode. In fact the turntable starts and stops and the display blinks intermittenly. In convection oven mode everything works fine - It heats, turntabl
The magnetron is the main part that gives out microwaves to heat the food. As the convection bit is working this points towards the microwave bits.
The magnetron has a main diode, fuse and transformer to run the microwave bit, any of these could be faulty. A word of warning though, there are extremely high voltages inside microwaves, even when unplugged in the main capacitor. Also to repair this section you will need to be a fully qualified engineer to even order parts for this.
Find a microwave technician who can repair for you
Nov 04, 2014 | Microwave Ovens
Oven suddenly lost heat, inside fuse is OK though. Display, fan, turntable all working. Is it magnetron or its power supply?
You're right, if the lights come on and turntable moves, it is most likely your magnetron.
Jan 23, 2011 | Microwave Ovens
Microwave doesn't heat.
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Sep 18, 2009 | Microwave Ovens
Microwave won't heat. turntable works control
Hi! check the fuse that goes through the magnetron because i think it is no functioning.
Sep 10, 2009 | General Electric Microwave Oven
My Whirlpool microwave is not heating. The light, turntable and fan is working. What is my next step? model MH2175SXQ-0
Jul 31, 2009 | Microwave Ovens
Microwave does everything that it is supose to do just that it does not heat and the noise to heat increased. This happend yeaterday.
Jul 30, 2009 | Goldstar MV-1526 Microwave Oven
Doesn't heat anything
HI, there is only one in-line fuse link that is designated for the power board. this is concerning the Magnetron. this heating device has failed. replacing the Magnetron will fix this issue.
Jun 17, 2009 | Emerson Black Microwave Oven
Microwave Smokes
the problem is in the magnetron try to replace it.
Jan 27, 2009 | GE JVM1660 Microwave Oven
Whirlpool Microwave no longer heating
Sounds like the magnetron has failed. It is the magnetron that generates the microwaves that heat the food. If it or the circuit that powers it fails then it stops heating. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
Jan 10, 2009 | Whirlpool MH1170XS Microwave Oven
GE JVM2050 Microwave Oven Logo
29 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
