Question about Gold Medal Kitchen Appliances - Others
Spinner wont turn - Gold Medal Kitchen Appliances - Others
Cloths spinner wont rotate under load
EITHER bad motor are broken belt ,if u. Don't know how to fix dryer call for service
Apr 03, 2015 | Dryers
Flames wont turn on and spin around
The bulb may have failed. Heat from the bulb is usually what turns the spinner.
Oct 28, 2013 | Heating & Cooling
When you turn the spinner on it wont work i'ts geting power to it but wont spin but pumps the water out
Check that the drive belt is on (you can find this underneath the machine if its a top loader, or in the back if it's a front loader) If the belt is on, check that the pulley turns freely, you may possibly be looking at a seized bearing or gearbox.
Jul 29, 2011 | Washing Machines
Top rack spinner is not spinning
First check - ensure that the jets at the end of the spinner blade are not blocked. Check that the spinner is not siezed by turning it by hand, other than a cracked or disconnected pipe, there can not really be another reason for the spinner not rotating (if the bottom one rotates).
Jan 15, 2011 | KitchenAid Dishwashers
I put the game in but the disk does not spin
try cleaning the spinner and laser and make sure the spinner and game make contact to where they spin. it might be that your tray is kind of crooked and it misses the spinner to where the game wont spin.
Dec 08, 2009 | Sony PlayStation 2 Slimline Console
The spinner bush turns really slowly. It doesn't
u need to get a new belt. a local hardware store or walmart carries it. also u need to take the vacum apart further so u can clean out where the motor spins u will get much bettter results
Oct 06, 2009 | Eureka Vacuums
The spinner wont spin
clog, take bottom apart and clean, keep cleaning it theres more in there
Sep 07, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
It turns on but the spinner underneath wont work now
Turn the vacuum so the bottom is facing up..
Take out the scews in the plate that surounds the brush and take it off..
The belt should be firmly on the brush and the motor..
If the belt has come off the motor - pull out the side of the brush that the belt connects to.. Put the belt back on the motor post and the brush.. It might be a tad tough going back in because the belt should have a little tension..
Once the belt is on and brush in place - put plate back on..
Hope this helps ;o)
Jul 15, 2009 | Bissell 3576 CleanView II Bagless Upright...
Spinner for the plastation2
mine to same thing it sucks doesent it
Nov 02, 2008 | Sony PlayStation 2 Slimline Console
Kitchen Appliances - Others Logo
53 people viewed this question
Top Gold Medal Kitchen Appliances - Others Experts
Coss
Ted Maxwell
Tom Chichester
Are you a Gold Medal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
