Question about Genie Garage Door. SilentMax 1000 3/4 HP Comparable Belt Drive Garage
Motor starts but stops almost immediately-long red LED flashing
Was working great since install of 8/13 & now just stopped running
Aeg electrolux dryer
Displaying the alarm code
The alarm code is displayed by a repeated sequence of flashing of the ANTI-CREASE/END OF CYCLE LED (0.4 seconds on, 0.4 seconds off, with a pause of 2.5 seconds between sequences). The buzzer emits a series of ,bips" in synchronization with the flashing of the LED.
  • ANTI-CREASE/END OF CYCLE LED: indicates the first number of the a alarm code
  • START/PAUSE LED: indicates the second number of the alarm code
Now you must count how many times the LED lit up and we will know the fault code.
24383347-wycorcio5u0xxoh2plbhrodj-5-0.jpg Dado
May 10, 2014 | AEG Dryers
STAND BY BLINKING LED 6 TIMES
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. For more information go to http://electronicshelponline.blogspot.com/
Nov 23, 2013 | Sony KV-35S26 35" TV
I have a Liftmaster Model 2500 opener. It is about seven years old, and worked great until recently. It has stopped working, including no lights at the Multi-function door control. If I unplug the...
THIS IS PROBABLY CAUSED BY A SHORTED WIRE.
OR A BAD WALL CONTROL.
DISCONNECT WALL CONTROL & TEST.
IF STILL NO RESULT DISCONNECT WALL CONTROL WIRES AT THE POWERHEAD & TEST AGAIN.
REPLACE WIRE OR WALL CONTROL.
HOPE THIS HELPS
Nov 15, 2010 | liftmaster Chamberlain Garage Door Opener...
My Indesit Moon 1400 has stopped working. Shortly after the cycle starts the blue LED lights at start and 40 deg flash rapidly. Washing inside machine is soaking wet but has neither washed nor spinned. ANy...
Tom, I'm having exactly the same problem, Have you managed to solve it? The Service center will no even tell me what's wrong with (they're quite keen to get me to arrange a visit from their engineer for £110 though). Thanks
Jan 30, 2010 | Indesit W 123 Front Load Washer
Red led flashes. when i try to turn tv on it shuts off immediately. it's a panasonic th-42pz700a
There should be a number of flashes that you can count. This is an error code. It will flash a number of times and stop. Again, Flash a number of times and stop. Contact a repair shop that is familiar with panasonic and have them to check it out.
Oct 14, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
PT54DL50
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Sony KP-57HW40 Error Codes 6 & 8
ITS PROBABLY THE RED PICTURE TUB (CRT). IT LOOKS EASY TO INSTALL, BUT YOU NEED TO MAKE ADJUSTMENTS TO THE SCREEN ONCE IT IS INSTALLED. THE PART IS $3OO. TRY TO FIND SOMEONE TO INSTALL IT FOR $150 OR LESS. HERE IS A WEBSITE TO HELP YOU MAKE ADJUSTMENT IN THE FUTURE ON YOU OWN.
PRIDAH
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Nov 10, 2007 | Sony KP-57WS500 57" Rear Projection...
Television won't turn on
If its a DLP tv chances are the bulb went out, double check with the manufacturer before getting as they are not cheap, around the $250 range.
Oct 26, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Genie Garage Door. SilentMax 1000 3/4 HP Comparable Belt Drive Garage Logo
74 people viewed this question
Top Genie Home Experts
Robert Plante
Terry Smith
Level 1 Expert
Brett Duxbury
Brett Duxbury
Are you a Genie Home Expert? Answer questions, earn points and help others
