Question about Generac Guardian 20kW Model : 5875
Won't start overcrank - Generac Guardian 20kW Model : 5875
How to diagnos Overcrank light
I don't think the over crank is a problem.
Why is it shutting off?
Find the owners manual to find out if there is some fault that will shut it down or it may be an engine problem like the choke not releasing after starting.
To find a manual online you will need the make and model number of your generator.
Aug 20, 2014 | Electrical Supplies
Overcrank alarm in Kohler Marlene engine
Overcrank alarm is coming because the unit failed to start
Mar 16, 2014 | Electrical Supplies
Overcrank when start
check the battery. Have a load test done to check for dead cell
Nov 20, 2013 | 2005 Pontiac Grand Prix 4dr Sdn GXP
Guardian propane generator hard starting. At 20 F backfires and won`t start. Goes to overcrank.
It needs a cold weather option, one that heats the oil and also the carb so the LP gas does not freeze the carb. A common problem
Nov 04, 2013 | Guardian Electrical Supplies
How to reset FAIL TO START(over crank)?
Over crank is just that too much cranking with a filed to start. Plese check gas pressure and for voltage on the fuel shut off solenoid
Aug 16, 2012 | Kohler 12 kW Emergency Power System -...
Generac 20,000kW Standby generator doesn't start shows message STOP ALARM OVERCRANKED
Overcrank means that it tried to start and couldn't. It will go through 5 crank cycles and then stop with this alarm. Switch to off, hit enter to clear fault and then try to start in manual. Check to make sure you have fuel and pressure is 11 to 14 in WC.
Jun 21, 2012 | Generac 13,000 Watt / 13,000 Watt Home...
99 f250 diesel wont crank
if it a standard check the cluch safety switch, i had a switch come apart on a f250 before and caused this
Apr 16, 2009 | 2000 Ford F250 Super Duty Crew Cabs
Overcrank error message
The 'overcrank' error simply means it tried to start but never actually started. It cranked for an extended period. Check the fuel and starting issues you would normally check to start the engine.
Mar 31, 2009 | Kohler 12 kW Emergency Power System -...
Won't start
That clicking you hear is the starter solenoid. There are two reasons for this, one is not enough power to crank the starter, but it looks like you have ruled out that possibilty. The other is the starter and/or solenoid are going bad. Although sometimes your starter can develop flat spots and prevent starting, If you are handy and can locate the starter, try tapping on it with a rubber mallet then try starting the car.(I've started alot cars w/ starter problems this way) If it starts then it's definatly your starter and it needs to be replaced. Flat spots occur from overcranking which cause's alot of heats, can also be caused by cranking when engine is already running. Anyway here's a few tips and I hope this helps
Jul 01, 2008 | 2000 Dodge Intrepid
Generac Guardian 20kW Model : 5875 Logo
Top Generac Electrical Supplies Experts
Craig Butler
Craig Butler
Ottoniel
dennys23601
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
