How many tons of refrigeration is this unit model 3 pa5536aka6
5 Suggested Answers
  • 34 Answers
SOURCE: Can a Goodman AC unit with a model number of a
they would need to change the coil indoors to a 3 ton. If the blower speed can be increased it should be fine.
Posted on Aug 11, 2009
Testimonial: "Thnx for the input. Looks like you were dead on."
  • 23 Answers
SOURCE: I have a 3 ton split system using a Rudd 3 ton
Both the other solutions are NOT proper Advice, i'm not saying this a put down, but if you want it to be right both of those answers are wrong
The truth is if you replace the condenser weather its a heat pump or strait cool, you need to match the equipment inside, ALWAYS use matched equipment otherwise your setting yourself up for failure. I've seen a ton of mechanics in my industry really mess people up by mis matching, Also you can install or service anything with refrigerant in it with out an EPA license. Trust me do it right, cause I hate having to tell people after its to late. Another thing these two are not telling you is that you need to match the metering device to the outdoor unit in order for it to work properly as well, and by the FLUSHING is risky on a coil, ok with line sets but risky with a coil.
Posted on Oct 01, 2010
heinzhvac
  • 229 Answers
SOURCE: I am removing a 3 ton condenser and replacing with
Yes you will have problems you can go up a 1/2 half ton on the coil but not with the condenser don't do it you will regret it even with an expansion valve.
Posted on Jun 21, 2011
  • 1015 Answers
SOURCE: MY UNIT MODEL # IS
I think you are right and it is a 3 ton unit. Thank you.
Posted on Sep 04, 2011
How to know the tons of old ac unit from the model no?
36 is equal to 36000 btu. To find the ton divide by 12000 btu. 12000 BTU is a ton of refrigeration. This is a 3 ton unit.
Jun 17, 2014 | Weather King 10AJA6001AH Air Conditioner
I am removing a 3 ton condenser and replacing with a 31/2 ton condenser . The evap coil is a 3 ton with an expansion valve with a 11/2 ton to a 3 ton rating. Will i have any problems. The 31/2 ton unit is...
Jun 21, 2011 | Heating & Cooling
Hi there I have a model number for my carrier a/c unit. I need to find out the tonnage. 38ykc042300 Please any help I will be very greatful.
This is a 3 and 1/2 ton unit.
The 042 in the model number is the tonnage of your carrier unit.
AC tonnage is based on 12,000 btu per ton.
12,000.....1 ton
18,000.....1 and 1/2 ton
24,000.....2 ton
30,000.....2 and 1/2 ton
36,000.....3 ton
42,000.....3 and 1/2 ton
48,000.....4 ton
60,000.....5 ton.
There is no 4 and 1/2 ton unit.
Apr 09, 2011 | Heating & Cooling
What is the HP rating if a 3 ton air conditioner?
Hi, this depends on the compressor that is installed in this unit. It may be a Copeland scroll, a Tecumseh, its hard to say. Most compressors are around 2 hp for a 3 ton unit. On the data plate it will tell you the h.p. of the blower and condenser fan motors such as 1/4 h.p., or 1/3. If you can get the name and model numbers from the top of your compressor, you can call a a/c, Refrigeration parts house, wholesale and they will have it in there manuals. The B.T.U. rating for your compressor is 36,000. There are 12,000 BTU's per ton of cooling, this is something that almost no one knows, but now you do. If it were a smaller unit such as a 2 and 1/2 ton, it would be 30,000 B.T.U.'s. You can look at the model number of a unit and you will see numbers like this, 024, 2-ton, 030, 21/2 ton, and 036 a 3 ton unit and so on. Your compressor alone will be in the range of a 2 horse unit, which ever the brand of compressor they installed in it. Please don't forget to rate me on this as I know you will be kind. I will be here if you ever need help on repairs or trouble-shooting your unit in the future, just use my user name below.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Sep 04, 2010 | Heating & Cooling
What size BTU unit is my Crarrier model 38ck036330 condensing coil ?
The model you gave is for a 3 ton or 36000 BTU unit...that is what the 36 stands for in the model number...
heatman101
Aug 24, 2010 | Carrier Heating & Cooling
Does not seem to be sufficient cool for a 1600 sq ft manufactured home coming from the Coleman unit installed. Some vents more air, others less air. Unit runs without stopping ever. Can you give us some...
Hi John, depending on the size, I would need the model number from the outdoor unit if it is a split system, you should have 400 cfm per ton of cooling. If you have a 1600 SQ' home, and a 3 ton unit, 3 x 400 cfm is 1200. It would be to small. There are 12,000 B. T. U.'s of cooling per ton. 2 tons would be 24,000 b t u's. 3 tons would be 36, 000 b.t.u.'s. Also, most contractors put lever dampers in the duct work that can be adjusted. They will put a red flag where the lever is and we can adjust the flow to balance out the house. I don't know where your ducts are, under or above, but with a good light find the crawl space and check it out. Get the model number and call it in to get the tonnage or send it to me and I will tell you. It will have a 024, 030, 036, 042, or, 060 in the number, MODEL number and figure like I told you above, 12,000 per ton. 060 would be a 5 ton. This will let you know if the unit is the right size or not. Please rate me on this and I know you will be kind. Thank you John.
Sincerely,
Shastalaker7
PS CFM is cubic feet per Minute.
Aug 05, 2010 | Coleman Heating & Cooling
Not cooling as it should
If you have a crushed, kinked, or otherwise restricted fitting in the system, it's possible the cooling may be affected. Pressure readings can be thrown off, and refrigerant flow can be inhibited.
Since the unit is new, you should have a complete parts and labor warranty, so ask the installer what the reason is that the system doesn't provide the cooling you were probably promised when they sold it to you. They should have taken into account the location of the condensing unit, the size and insulation in your house, indoor and outdoor conditions, your geography/climate, and any other load factors before selling you the system.
Jul 22, 2010 | Goodman CLQ36AR49 Air Conditioner
We are replacing a 22 year old ruud UACC030/36AHW38 (this is listed as the equipment being removed from our home by one of the companies who has given us a quote). One of the companies is telling us that...
Hi, there are 12,000 btus per ton of cooling. You go by the numbers in the model number. I see you have a 030 which would be a 21/2 ton. I also see a /36a which could stand for a 3 ton, but its the 030 number you want. It is a 2.5 ton unit, no question! 2x12 is 24+6=30,000 btus, a 21/2 ton unit. Hope that cleared it up for you.
Sincerely,
Shastalaker7
Jul 12, 2010 | Ruud UBHC Air Conditioner
I have a Ruud Model # UACC-036JAS. Any idea on
Hi, yes the number you are showing me 036 indicates its a 3 ton unit. For every ton of cooling, you will have 12,000 btu's of cooling. 36 divided by 12=3 ton unit. Its showing me also its a Ruud Handler 2.0 ton which would be a Model# UACC-024JAS? If your mobel number is the one you gave me, UACC-036JAS, this is a 3 ton unit, absolutely no questions. I hope I have been of help to you. I am a licensed air conditioning / Refrigeration /Heating Contractor. Let me know if I have been of help.
Sincerely,
Shastalaker7
PS If this is a split system with the indoor air handler and condenser outdoors, both coils must be the same tonnage for it to work for you properly. You can't have a 2 ton indoor evaporator coil with a 3 ton condensing unit.
Jun 28, 2010 | Ruud Handler Air Conditioner
What is the tonage on a 10aja3601
Hi, the tonnage of your unit is a 3 Ton unit. There are 12,000 btu's per ton of cooling, so your model number has a a36, so 3 x 12 = 36 which is 36 = 3 tons of cooling.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration, Contractor
May 15, 2010 | Weather King 10AJA3601AH Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
