Question about Dell OptiPlex GX260 PC Desktop
My compnay had several of these machines.. all the same problem.
The will not power on, no indicator lights on the back. Sometime they will power on after being plugged in for an extened time, then work ok until they loss power. Its not a power supply problem .. just something does or does not get energized .
    Sergeant:
  • 268 Answers
Try resetting everything in the system and check you have no messed up fans. Sounds like your processors are overheating and failing
Company site http://www.attechcomputers.co.cc
Posted on Jun 18, 2009
Elma 7100wTHread gets tight in the pickup and then breaks. Sometime I can free motion for several minutes before this happens.
The top thread is snagging & hanging up somewhere in the thread path. Sometimes it's because it has looped around a guide or even the spool pin or possibly it is mis-threaded. Being able to stitch 3-6" is indicative of this issue as it takes that long before the machine "runs out of thread" before breaking.
Remove the top thread completely from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Feb 20, 2017 | Elna Sewing Machines
Blanks after 2 seconds
The problem is in the inverter board, caused by bad capacitors that sometime bulge at the top indicating it is open. The inverter board powers the back lights behind the screen.
Feb 15, 2011 | Envision H22W 22" Monitor
I have SAMSUNG HL-S5087W that sometime shuts off several times a night. And sometimes not at all. Heard there is specific part that is not very hard to change. Any help out there?
Yes,it is the tv projection lamp.When it is shutting down several times.The LED "LAMP" light indication flashes or stay on.That the indication the projection lamp life are ending or near the end.Require a new tv projection lamp.
Dec 04, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Error code F1 and UL
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*%#
Jun 13, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Engine dies out
Could be any of several problems. Since you indicate you just bought it, I'd suggest you return it. Troy-Bilt is pretty good at making customers happy and should repair or replace it right away.
Apr 09, 2010 | Troy-Bilt Pony Garden Tiller
Whirlpool Cabrio F1 trouble code came up 3x recently. Called Whirlpool and they said washer was out of warranty. Once I told tehm about the post they said that it was a Whirlpool "Quality Issue" and would...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%$@#
Jun 12, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Dell OptiPlex GX260 PC Desktop Logo
54 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
