Question about Smeg Ovens
Smeg oven buzzing sound - Smeg Ovens
Why is my oven not heating up?
Call an electrician. Sounds like a thermal cut out or a bad element.
Jul 17, 2014 | Smeg Ovens
Lots of water/condensate ends up on bottom of oven
I have the same problem with my new Smeg oven. I try to avoid using the oven at the moment because of the amount of condensation I have to mop up each time I use it, even the floor get wet!. Smeg have said they will replace it but I am now looking for an oven that will fit into the 'whole' the oven will leave in my newly renovated kitchen. I wish I had never ventured near to SMEG. I would never recomend Smeg to friends, quite the opposite.
Jan 19, 2010 | Smeg F170 Pyrolytic Stainless Steel...
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
Smeg oven ss336-5 not heating
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on Facebook please How to Video Tutorials on Domestic Appliances
Jan 21, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven
How long is the oven in operation before you check the air flow ? Most Smeg ovens are electronically integrated and sensitive.
Jan 24, 2008 | Ovens
REQUIRE AN INSTRUCTION MANUAL FOR A SMEGG SE378 MFX5 OVEN
You can get instruction manuals for all smeg products by following this link http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN
Dec 06, 2007 | Smeg Ovens
Ovens Logo
19 people viewed this question
Top Smeg Ovens Experts
ashburton
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
