Question about Dell OptiPlex 170L PC Desktop
Pnp who to disable
    Top Expert:
  • Dell Master
  • 14,161 Answers
Acer S232HL driver did not install I want it instead of the Generic PNP driver. Help please
Good for you Barb, in the future be aware the for display adapters you can simply remove them and you would be prompted to re-install a driver for it at reboot.
It will by default use a generic monitor driver so you just cancel out the install and then run the setup off the CD.
regards,
Mike
Oct 07, 2012 | Acer S232hlAbid 23 LED LCD Monitor 2 ms...
How can I resolve P1706 for Nissan Altima? I replaced PNP switch...
There are only 3 possible causes for that code.
1. Open or shorted PNP sensing circuit between the PCM and the ground for the PNP switch.
2. Faulty PNP switch
3. Defective PCM or possible PCM software update
> I searched for possible Technical Service Bulletins (TSBs) that may address this concern or authorize a software update to correct the problem and found none.
> You have already replaced the PNP switch.
> PCM failures are extremely rare.
This leaves us with an open or shorted circuit that needs to be traced. (which, incidently, should have been checked before replacing any parts.)
Please also review this article:
What Else Could Be Wrong?
Sep 10, 2011 | 2002 Nissan Altima
Hi guys! I badly need a help. hope someone can help me solve my prob in my averatec 6200 series. i just upgraded my OS from windows XP to windows 7. in my performance rating i always get a 1.0 rate bec of...
Hi, it does not matter which monitor the Notebook has, the ratings may change depending on the Hardware performance of the Notebook, Please make sure you have installed all the latest Drivers for Windows 7 OS. Usually the notebook manufacturer will release Drivers for Windows 7 OS in there Website. If you are using Windows XP Drivers for Windows 7 then the performance may vary.
Please check your Hardware Specification by downloading Speccy program from the below link:
http://www.piriform.com/speccy
Please follow the below steps to enable Hardware Acceleration.
1. Choose Start > Control Panel.
2. Double click Personalization and select Display Settings.
3. Click Advanced Settings.
4. Click Change Settings on the Troubleshooting tab.
5. Move the Hardware Acceleration slider to Full.
6. Click Apply and then click OK to accept the new setting and close the dialog box.
7. Click OK to close the Display Properties dialog box.
8. Restart Windows.
Apr 13, 2011 | Averatec 6200 Notebook
Cant even start up in safe mode
during the boot up process for a short time you will see press a certain key to enter set up
press that key to enter BIOS scroll to PnP/PCI configurations the default is disabled
select enabled to reset configuration if you have installed a new add on and it has caused a serious conflict that the operating system can not boot
hope this helps
don
Feb 26, 2011 | Acer eMachines 350-2074 Netbook
Scsi/raid host controller
redux1
its old
hp.com has no driver page. now.
end of life for that and XP for 3 years now.
so....
join the HP.forum
then ask for the correct SATA driver
post your PCI codes.
click CP
click DM
click your bad, SATA chip driver.
below is NIC, example, only
then post them on hp link in my 2nd post;
Mar 19, 2017 | HP Pavilion s7310n (EN996AA) PC Desktop
Will not power up when network cable attached
There is a Wake On LAN support on netvista 6792
and possibly this may be the reason
First, go into your BIOS, find the PnP hardware settings and disable Wake-on-LAN (it may be in a different category depending on your BIOS).
let me know if this has been perfrom
Jan 28, 2010 | IBM NetVista PC Desktop
PnPDeviceProblemCode
Even i had this problem.
Follow these steps it may be of help to you.
1. Go to Device manager.
2. Insert the SD card.
3. When the SD card shows up in the device manager with an alert, right click and say disable device.
4. Go to Services and start PNP related services if it is not started.
5. Again right click and say enable device.
6. It shud update the driver software and your device may be detected successfully.
7. Enjoy :)
Cheers,
Raghu
May 27, 2009 | Dell Studio 1537 Laptop Computer PC...
Need to know jumper settings to disable onboard ethernet i have installed a ethernet card but i cant get them to not have conflicts
You probably just need to go into the bios setup to disable the on-board controller. If it is a dell, you usually just hit F2 when booting up to access the setup screen.
May 05, 2009 | Computers & Internet
My computer stops at PNP init complete
Try the following
go into your cmos. By pressing either Del key F2 key or another combination of keys. Then navigate to pnp in the bios and set to off no
Jan 22, 2009 | Computers & Internet
When I hook up my acer monitor it says no imput
Before making sure you have all the plugs & connections in the right place, look at all the pins on the end of the monitor plug that plugs into your on board/video card making sure none are bent or missing. If not, then try swaping with a known working monitor. If good monitor doesn't work either theres a good chance you may need to either add or replace video card.
If none of these options work you can let me know and I'll try to suggest something else.
Jul 27, 2008 | Acer Computers & Internet
Dell OptiPlex 170L PC Desktop Logo
60 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
