Question about Avalon Ezc Voice Series Low Vision Talking Watch 2608
Lifemax time change - Avalon Ezc Voice Series Low Vision Talking Watch 2608
Date does not change after 12:00 am
Does it change at all? You may just have to set the time 12 hours later so it changes at midnight not lunch time
Nov 30, 2013 | Neff Flava White Digital Watch
Change time
Advance the time by 23 hours. And reset the day to the correct one. make sure that the date change occurs at midnight your time and not at noon.
Nov 07, 2013 | Swarovski Authentic Crystalline White...
How to change time on roots watch ry2203
Press and hold "MODE". Press MODE 2 times (after the first time, the alarm time flashes, after the 2nd time, the second flashes). Press ADJ to change seconds. Press ST/STP to switch from seconds to minute. Press ADJ to change minutes. Then press ADJ to change hours. Press MODE when done.
Apr 06, 2013 | ROOTS Athletics Wrist WATCH Water...
I need instruction for a lifemax ladies watch
For Lifemax watch instructions, go to http://www.rnib.org.uk/shop/Pages/Category.aspx?Category=talking_watches
and select the model of Lifemax watch for which you require instructions.
When that product page opens, scroll down to find 'product instructions'. Click on that to open the instructions in a Word document (you will need to have MS Word or the free OpenOffice suite to read it)
Jun 02, 2012 | Watches
The watch shows time in digital plus has hands on it like a regular watch the digital shows one time and the hands show another
Hi jessestaton,
All you would have to do is change the time from either the digital mode or the anolog hands , you can choose one which is incorrect and try to change it.
Now to change the analog clock's settings , you would have a button which you can manually rotate and set the time, this is how you would be able to recognise that it's for the anolog time modification.
If you need to change the digital time , all you have to do is find out buttons that are present on the watch , and then try to change the time.
Note:- If you find a circled knob , remember that could only be for anolog time change as digital time is never changed using such knobs or screws , but have seperate button for that function.
In case you have any queries, feel free to get back.
Hope this helps ..:)
Jun 12, 2011 | Watches
How do i change the date on my tag heuer formula 1? i know how to change the time. I went to change the time and in doing so it changed the date. when i went backwards it would not change back
You change the date the same way you change the time. The only difference being pull the crown out 1/2 way to the first click instead of all the way out.
Oct 19, 2010 | Tag Heuer Formula One
How do I get the hourly announcement option to work on my Lifemax talking analogue watch model 411.1?
these can be tricky as they sometimes have 2 batterys in them one for the hands and one for the talking function it maybe your talking battery needs replacing try this first.
Mar 26, 2010 | Bulova Watch
Time change Fossil JR 9120
i already found one link with all Fossil manuals.
Thank´s for your support.
Feb 08, 2010 | Fossil Fuel Josh JR9120 Watch
Cannot change from 24 hour to 12 hour also did not change to daylight savings time
To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
Mar 08, 2009 | Timex T5G341 Sports Radio Control Watch
Casio watch 3793 cannot change time
the best you can do follow these steps:
lests say
the top left button is a
the lower left button is b
the light button is c
and the lower right is d
to change digital time, when in time/date mode hold a untill seconds start flashing. then you can change the seconds. hit d do change seconds.
then you hit b wich brings yyou to Daylight savings, change with d
then hit b to change to hours, you can go up and down digits with d and C(LIGHT) then hit b to minutes and so on.
then hit a once to confirm and again to toggle from date to time
for analog time changing:
in time mode press a six times until it says: "h-s"
then hold a until the display flashes then press d for every minute you want to skip, you can also hold d and then press c it automaticly starts changing then hit d to stop(and maybe correct with a couple of "d's"
hit a to confirm.
there you go
Oct 26, 2008 | Casio Casual Sports Watch HDC6007BVCF
Avalon Ezc Voice Series Low Vision Talking Watch 2608 Logo
19 people viewed this question
Top Avalon Watches Experts
Ngoro
Ngoro
TStevens
Are you an Avalon Watch Expert? Answer questions, earn points and help others
