Question about Pentair Minimax NT Heater
Error 05 The heater won't fire up, but he blower works.
    Champion:
  • 305 Answers
Check to see if ait pressure switch is closing. blower may not be producing enough pressure to close the air switch. check the air switch tubing and heater venting for any blockage
as well
Posted on Apr 14, 2014
05 tahoe blower motor do not stop
check blower motor resistor connector could be burnt or resistor it self
Jan 30, 2015 | 2005 Chevrolet Tahoe
Heater ac fan won't blow 05 silverado. Started truck on cold day fan was blowing and turned it off waiting for truck to warm up and heater would not come back on. Checked all the fuses, all were good. Fan...
Test the electrical circuits ! Manual HVAC or automatic HVAC ?
Do you know the difference ? Heater / A/C blower motor electrical control diffrent . Manual has resistors an a relay for different speeds , automatic has a blower motor control module .Free wiring diagrams here http://www.bbbind.com/free-tsb Enter vehicle info year , make , model and engine size . Under system click on HVAC ,then under subsystem HVAC controls will pop up . Click the search button , then the blue links . First off you need to know what system yours has , manual or automatic.
GMC Yukon HVAC Blower Motor Won Turn On
Blower Motor Problems Auto Repair Help
Feb 27, 2018 | 2004 Chevrolet Aveo
Heater won't turn off. Error message on display panel says "c". Heater blowing on High.
Disconnect neg / grnd battery cable. Replace Heater Blower Resistor. This will allow the heater blower to operate correctly
Mar 03, 2013 | 1989 Cadillac Sedan DeVille
Have a gmp125-4 furance blower runs all the time checked themostat wires error code 1 blink then 2 then 3 then 5 furance works if you turn power off turn back on when heat kickes off blower comes on gives...
Sounds like limit switch issue. Furnace heats up, high temp limit switch opens, fan will stay on. GMP model is older and do not have the codes.
May be over fired, have airflow problem, to cause the limit to open.
Next time before shutting off power, try to find the limit, it has two wires that connect to a 1.5 x 2 inch card mount to the furnace fire wall. tap on it and see if the blower stops. If so replace the limit.
Sep 06, 2011 | Goodman Heating & Cooling
My 05 durango front A/C / Heater blower motor quit working all of the sudden. The rear controls still work fine. Not sure if it is a fuse, relay or something else simple. thank you
For similar issues always check the fuse first. Check if all speed are gone. It also could be the resistor that is connected between the switch and the blower. It cold also be loose wiring. You may need to inspect the said parts which is found behind the glove compartment.
Aug 21, 2011 | 2005 Dodge Durango
Blower runs but no ignition then AO error code
Your problem then would be the pick up tubing and/or switch attached to the blower that closes once the blower is on to allow the heater to ignite. Pull the tubing and check it for dust or other debris clogging it and check inside the blower housing for the same. If you can test the switch under operation, you should see it remains open during start up which is why the burners won’t fire. If you do not find any obstruction (if you can, blow some compressed air thru too just to be sure) then you will need to replace the switch.
Jan 04, 2010 | Hayward H Series Pool & Spa Heater 400k...
Blower runs and have ignition and fuel but fire won,t stay on . all pro spc-85 construction heater.
Most likely the flame sensor. The sensor has only one wire to it and is L shaped. Unplug the heater and take some steal wool and gently clean the the sensor.
Jan 02, 2010 | Heating & Cooling
Error code AO defined as blower vaccum open
I just had same code. I took off top cover and found the end of the hose attached to the blower was split and not attached securely. Attaching hose solved the problem for me and heater fired up.
Mar 19, 2009 | Hayward H Series Pool & Spa Heater 400k...
05 lancer does not not blow out air when heater is on
sounds like a loose connection since it works when slapped. pull the switch out and check the connections. if this works please rate joe
Nov 22, 2008 | 1993 Buick Regal
Pentair Minimax NT Heater Logo
51 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
