Question about 477L Ask RXTX HHU Remote
How to install python 594 in a diesel - 477L Ask RXTX HHU Remote
    New Friend:
  • 4 Answers
Install like a regular remote start alarm. You will have to tap into the glow plug wire, and change the setting on the brain to "wait to start" for the glow plugs.
If you have not installed a remote start alarm before:
1.install the siren under the hood and run the wire through the fire wall into the cab.
2. Mount antenna at the top center of the windshield then run wire around and down to drivers floor.
3. mount shock sensor with a ziptie to the steering column (as long as the steering column doesn't move/rotate)
4. separate the wires you are going to need, from the ones you won't need.(specific per vehicle):12+, Gnd, Parking lights, IGN, IGN2, ACC, ACC2, Starter, lock, unlock, brake, glow plugs...
5. zip tie and tape off the unused wires.
6. use wire diagram and find then test the vehicle wires.
7. connect RS/Alarm to vehicle, plug in antenna and shock sensor, then attach siren.
8. BEFORE DOING ANYTHING ELSE-GO INTO PROGRAMING AND CHANGE THE SETTING FOR A DIESEL !
9. now you can test the functions of the RS/Alarm,
BE SURE TO KEEP A WINDOW ROLLED DOWN, OR HAVE A SET OF KEYS OUTSIDE THE VEHICLE!
Posted on Apr 14, 2014
Python 594 install guide
http://www.directeddealers.com/manuals/IG/Python/N5904%202011-09b%20web.pdf
Apr 13, 2014 | Responder 594 HD SST with Remote Start
Where to tie in the H2/21 wire turbo timer mode on a python 594
First you need to tell us what car you connecting the alarm to. But google the car and where the wire locations are for alarm hook up.
Python car starter
Can you remove the python box without removing the wiring? That'd be a pretty definitive way of determining if the relays inside the python box are bad. On another note, this sounds like an ignition switch issue, the python box could just be coincidental.
Sorry, not much help... but see if you can eliminate the python box. That's the diagnostic process with electrical is to remove possible causes and record the results. Next, you might consider unplugging the wire harness from the ignition switch... or remove the wire harness that leads up the steering column.
Oct 16, 2013 | Vehicle Parts & Accessories
I am putting the python 5103p in a 2008 Ford F250 Diesel. What module do I need for it
If your Ford 250 Diesel is equipped with an immobilizer key (PATS) then you have two options. One would be the PKALL and you can find more information about the unit at bypasskit.com. It comes ready to install out of the box with no programming necessary. It requires two programmed keys to program the module. The next option is using a programmed key inside a universal bypass module (keybox).
Nov 23, 2010 | 5103p 1way Security System With Remote...
477L Ask RXTX HHU Remote Logo
76 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
baire
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
