Question about Behringer U-control Umx490 USB/midi Keyboard Controller
UMX 490 reset factory settings - Behringer U-control Umx490 USB/midi Keyboard Controller
Patch not saving,write button is not working from the day i bought.i bought is 2nd hand.plez help
If you buy a second hand, it may have been damaged in mini switch (tact switch) under the WRITE button. You need to replace the tact switch. Easy and inexpensive, you can do yourself, only with a little knowledge of soldering
Tact Switch:patch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-1.jpeg
You may also try the FACTORY RESET.
Restoring the GT-10 to the settings made at the factory is referred to as a "Factory Reset."
Not only can you return all of the settings to the values in effect when the GT-10 was shipped from the factory, you can also specify the range of settings to be reset.
If you do this"Factory Reset", all the setting on user memory (that you create) will be erased, so backup your setting before doing this steps.
patch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-3.jpgpatch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-6.jpg
For more detail on "Factory Reset", read the GT10 user manual:
roland.com/support/article/?q=manuals&p=GT-10&id=1810803
Sep 16, 2015 | Roland Boss Gt-10 Guitar Effects Processor...
Anybody ever figure out the Alesis DM10 module blank screen with some led lights on?
Try a reset before going to assistance:
There are two ways to reset the DM10:
To fully restore the module to original factory settings, hold the EXIT and STORE buttons while powering on the module.
To reset only the kits, sequences, or trigger settings:
  1. Press UTILITY to enter the main Utility Menu.
  2. Press SYS (F4) to access the Accompaniment Settings.
  3. Press INIT (F2) to access the reinitialization page.
  4. Use CURSOR UP/DOWN to move through the following menu items:
    • All Kits: All of the module's kits and their settings will return to factory default
    • All Sequences: All of the module's sequences and their settings will return to factory default
    • All Trigger Settings: All of the module's trigger settings will return to factory default
  5. Highlight the option you would like to reset, then press EXEC (F4).
  6. A window will appear asking you to confirm your choice. To confirm and reinitialize the selected settings, press YES (F1). To Cancel, press CANCEL (F2 or F2).
Aug 20, 2015 | Alesis Music
How can i do the reset factory for a piano Casio Privia PX-120?? It have the tone/settings button but not the function button. anyone know?
You don't need to reset factory.
You just need to change the setting of LOCAL CONTROL.
Lets start :::
While holding TONE / SETTING button,press key D#7 at 7th octave (highest octave on the right hand). Then release. That's all.
Then the sound must be heard..
Mar 12, 2015 | Casio PX120 Privia KEy ESSENTIALS BUNDLE
How do i reset the keyboard to factory settings? It sounds really weird right now
You can normally reset Yamaha keyboards by holding down the highest note while turning on. If you want to do a full factory reset see below - remember this may delete all songs etc you have saved to the keyboard memory.
decdbba2-706f-4a8a-afd1-ac3a6264c7f4.jpg dcd670d5-cf98-45e6-87a4-0591820eb4ef.jpg 2c144414-99a6-4025-960d-eaef496036a3.jpg
Jul 20, 2014 | Yamaha DGX-230 Portable Grand Piano
Factory settings
With IDES4, I can load factory defaults to my WK8000.
WK500 uses DATA MANAGER 5.0. If I am not mistaken, you can only save/restore/delete "user data" from and to the instrument.
FACTORY Settings are always unchanged in the instrument and it reset itself every time you power cycle.
Jan 15, 2014 | Casio Wk500 Wk-500 Keyboard Workstation...
HOW TO RESET BOSS GT3 GUITAR PROCESSOR TO FACTORY SETTIGS
Turn off and restart while holding down "mod" and "sfx", then answer a choice or two about starting point and ending point, just move curser to the beginning.
Mar 09, 2013 | Music
How to reset the pedal 25 ME? thank you.
You can restore the settings in the ME-25 (memories, tuner
reference pitch, and knob response method) to the values set when
the unit was shipped from the factory.
Performing a factory reset causes all settings saved in memory to be
lost. If you want to keep the memory settings, use the ME-25 Librarian
(p. 11) to save them on a computer.
1.
Hold down [EXIT] and press the MEMORY DOWN
pedal at the same time.
"FA" appears in the display.
2.
Press [WRITE].
The Tuning Guide flashes.
3.
Press [WRITE] again.
The display flashes and the factory reset is executed.
Never turn off the power while factory reset is in progress.
Feb 15, 2011 | Boss ME25 Guitar MultiEffects Pedal with...
I bought an Alesis SR-16 drum machine from an online seller advertised as "new". I plugged it in, and it appears that my "new" machine has had all the factory preset patterns erased! Is there a way to...
Hi.
The SR-16 has 50 preset patterns that are built in, I do not think they can be deleted, if there are no patterns the unit may be defective, even if patterns can be reinstalled using an rmidi file or re-flashing the unit.
To reset an Alesis drum machine you have to hold down both Play and Erase buttons while you power on the machine at the same time.
If that does not work, the presets are held into an rmidi file , the Rmidi file is not available for download. I think it can be purchased contacting Alesis or Rmidi.
I quote from Alesis Rmidi page:
"A rMidi Import/Export File named 'Sr16PresetKits.xml' containing the Sr16 Preset Kits has been installed within the folder named 'Sr16' within the directory in which you installed the rMidi FrameWork software. You can Import these Kits into the rMidi Drums Control if you wish. "
Check if you have the file in the folder.
If not the Sr16 will allows you to export your User Drum patterns, but I do not think you can export factory patterns.
Nov 20, 2009 | Alesis Sr 16 Stereo Drum Machine
Behringer U-control Umx490 USB/midi Keyboard Controller Logo
61 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
