Question about Zenith Dtt901 Digital Tv Tuner Converter Box
Digital converter box hookup - Zenith Dtt901 Digital Tv Tuner Converter Box
How do ihook up to a second tv from ikonvert digital box
your going to either buy a share, Y-cable to run both tvs, or switch box to select the tv you want to watch a that time
the connector on the tv has to match the connectors on the converter box.
just remember you will be watch same channel at the same time
you could also leave everything hooked up, than get Y-connector and put on the output of the box run line to each tv your still be watching the same channel without doing a lot of work and time
Mar 10, 2015 | Supersonic IKONVERT Digital TV Converter...
T.v. too old for dig. converter box?
digital converter boxes have singal coaxial outlet hookups as well, if the one you bought does not you can also puprchase an rf modulator. But keep in mind you do not need a digital converter box at all unless you are gettin your signall form an outsie atatenae
Jul 01, 2010 | Televison & Video
I want to hookup my insignia converter box to my dvd/vcr and my tv so I can record programs. What do I need to do. I have a 2 year old Toshiba Dlp and an Allegro dvd/vcr
Cable from wall to "cable in" on converter box.
"Cable out" from converter box to "cable in"on vcr. "Cable out" from VCR to TV "Cable IN" DVD should be hooked to VCR by way of Composite cables Red,Left, Yellow, Video White Right. There you go! THanks, Dana
Aug 16, 2009 | Insignia Digital-to-Analog Converter for...
How to hookup dtv to vcr
no,you must use a converter box to pick up the digital channels.the analog tuner in your vcr is longer used by the networks.
Jul 28, 2009 | Televison & Video
Getting my VCR to record from the TV with a converter box hookup
Hook up antenna to converter box then from that out to the vcr's input (red,white, yellow connections are better than coaxial).
Jan 20, 2009 | Insignia Digital-to-Analog Converter for...
Want to continue to record on my VCR after digital hookup
You have to use the RCA plugs on the back of the converter box and the tv (red,yellow and white). Or you can attach the antenna wire to box and then attach the wire that comes with the converter that is listed as to the tv and instead attach it to the antenna in on the vcr. The converter box will determine which channel your vcr will get a singal to record from. Your VCR for every program will be set to channel 3 or 4 (depending on what your converter box is set to broadcast on). Make sure the power saver on the converter box is turned off as if you want to record a program in say 4 hours, if the converter box turns off in 2, your vcr will have nothing to record.
I ran seperate coaxible cable to the tv from vcr and unplug the tv converter box everytime I want to watch the vcr. You can also use the RCA cord to send the signal from the vcr to the tv and use the input signal to watch your recorded programs. I had static showing up everytime I played it through the second converter box thus I solved it by running a seperate coax line. I don't know if you will have this problem, just wanted you to be aware.
Jan 12, 2009 | Insignia Digital-to-Analog Converter for...
Digital to analog converter box hookup
You will have to go to Radio Shack or Wall Mart, maybe Home Depot and get a matching transformer. That will have spade terminals on one end to connect to your tv and a round (75ohm male thread) to hook to your converter box.
Jan 08, 2009 | Televison & Video
Need help with digital converter box hookup
I located my owners manual and was able to resolve the issue
May 23, 2008 | Televison & Video
Dtv ready?
Usually on the back of the set there will be a hookup for digital tuner. To get the converter box before Feb 2009 go to http://www.dtv2009.gov
Mar 15, 2008 | Orion STV2763 27" TV
Zenith Dtt901 Digital Tv Tuner Converter Box Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
