Question about As Seen On TV Easy Stitch Mechanical Sewing Machine
Adjust timing on machine - As Seen On TV Easy Stitch Mechanical Sewing Machine
    Habit-Forming:
    New Friend:
  • 36 Answers
It is not easy to do. Home machine may be OK but not commercial ones.
Posted on May 01, 2015
Singer touch & sew model 625 won't pickup the thread from the bobbin.
If you are threading the machine correctly, the perhaps the bobbin and needle timing may be off. If you open and look at bobbin case; there is a hook. As you make the needle go up and down you can see if it is aligned or not. You can adjust the timing arm (screw) that allows the needle to go up and down to adjust the timing. It is located behind the face plate (left side of your sewing machine that opens). This link may show you what you are looking for.
http://www.wikihow.com/Adjust-Sewing-Machine-Timing
Jul 03, 2017 | Singer Sewing Machines
What does out of time mean in reference to sewing machines?
Certain things during the process of sewing must happen in a timed order for the machine to do its job, that is timing. To adjust the timing go to the link for help. How to Adjust Sewing Machine Timing
Feb 08, 2017 | Sewing Machines
Step by step how to adjust the timing on my empisal dress maker 270D
Search the internet for:
sewing machine timing
There are multiple web sites an videos available.
Jan 03, 2017 | Sewing Machines
Adjust the timing
May I ask WHY you want to adjust the hook timing? What makes you think that you need to do so?
Oct 17, 2014 | Singer Curvy 8770 Electronic Sewing...
Singer sewing machine timing adjustment
This is an often asked question. Also, you didn't mention which model you have. Regardless, I always answer that with another question, and that is--why do you think the timing needs adjusting?
Aug 31, 2014 | Singer Sewing Machines
Adjust timing on singer
what timing are you talking about? If is needle timing, remove the left cover of the machine and try adjusting the timing from there . If the problem is more complex, you will have to remove the bottom of the machine. It's not difficult but, if you need any help, I will guide you step by step.
Aug 04, 2014 | Singer 4411 Sewing Machine
Singer7462 timing adjustment
try these sites
youtube
fixsewingmachine.com
Mar 04, 2012 | Singer 7462 Mechanical Sewing Machine
How to check timing on pe180d embroidery machine
In case of adjusting sewing machine timing, there are twomain parts that you should follow.To adjust the hook needle timing on the rotary hook, first,remove the bobbin, bobbin carrier, and covers so you can see the movement ofthe hook. This may involve removing the needle plate for top loadingassemblies, or removing the hook cap from the front of the machine. Itoften requires the removal of the lower covers to reach the componentparts. Adjust as needed when doing sewing machine repair.Set the machine to a straight stitch at the defaultposition. Different models have different default positions including themost common far left and center positions. If no problems are perceivedin needle bar positioning, the default position will suffice. If thereare needle bar position issues, these need to be adjusted prior to adjustingthe timing. Follow proper sewing machine repair procedures.Rotate the hand wheel toward youuntil you see the needle reach its lowest position and begin its rise. Now lookfor the point of the hook as you continue rotating the hand wheel. Thepoint of the hook should strike inside the needle scarf above the needleby about 0.5mm. Sewing machine repair is vital for smooth operations.Check to see if the hook fails topick up the thread. Double check the needle bar positioning including thehook needle spacing. If these are appropriate and the point of the needlestill fails to pick up the loop thread, proceed to adjust the timing of thehook. Maintain regular sewing machine repair. Look for the lower drivemechanism. It may be a lower shaft with gears on either end. If this isthe case, look to the right end of the shaft for a gear with adjusting setscrews. Loosen and manually adjust the position of the hook. Tightly hold thehand wheel while turning the drive shaft to set the proper position. Retighten adjusting screws. Some models have timing beltsthat control the timing of the sewing machine. Look for a belt connectedon each with to drive gears. Look for work cogs on the belt. Inmost cases, you can reset the timing belt, without replacing it. If,however, the belt requires replacement you will need to do so. Loosen the drive mechanism on the right side to free the movement of the belt.Manually adjust the position of the hook to the needle and re-tighten set screws. This knowledge is vital for effective sewing machine repair.Once the timing has been reset,conduct thorough test sewing on the sewing machine to make sure everything isworking properly.Hope this will help you. Good Luck.
Oct 16, 2011 | Brother Disney PE-180D Computerized Sewing...
As Seen On TV Easy Stitch Mechanical Sewing Machine Logo
Top As Seen On TV Sewing Machines Experts
CrisO
Chance Miller
R.A. Ellis
R.A. Ellis
Are you an As Seen On TV Sewing Machine Expert? Answer questions, earn points and help others
