Question about Durabrand CD Player with Cassette Recorder, CD-2036 (Silver) Boombox
Cassett belt for model #1492 - Durabrand CD Player with Cassette Recorder, CD-2036 (Silver) Boombox
GE 3-5027 portable cassette player/recorder belts
I have a GE Battery operated Cassette Recorder, model no. 3-5025A and the spinals that turn the the cassette will not turn. I believe I need the 3 tiny belts that make it work need to be replaced. The are different sizes, do you know where I can purchase these belts?
Mar 15, 2014 | General Electric Cassette Recorder &...
I am looking for a cassette drive belt for the Philco model MO745 compact stereo
I do alot of repair work on older cassette decks & vcrs,Go to this link...
www.studiosoundelectronics.com/cassette.htm#BELT & they will have what your looking for.When you measure the belt per site instructions,make sure you allow for belt stretch(order shorter then what you have) Good luck..
Jan 19, 2010 | Audio Players & Recorders
My cassette deck Onkyo model Ta 2060 is working slowly
HELLO
By the fault you describe this sounds very much like a belt problem. Take the case off the deck and check the belt(s). Some decks can use more than one belt and you need to look at their condition.
Are they too slack around pulleys maybe? Belts don't last forever and I'm not too sure of the age of your deck. But personally, I would change them all.
Make sure the tape path is clean as well, clean heads, pinch roller and capstan.
Dec 14, 2009 | Audio Players & Recorders
I have a sony shelf system with combination cd and cassette - bel
Sorry, we have no belt listing for your specific model, but we do likely have what you need........
If you still have the old belt intact:
> Lay it out flat on the table
> Pinch it at both ends & straighten the belt but don't stretch it.
> Measure the length & then double it and choose or we will recommend
a size about 3-5% smaller.
Old belt too far gone to measure:
> Just use a piece of string and thread it temporarily in place of where the belt goes.
> Then measure the length of the string and Email us the exact length (inches). Along with your EXACT model number.
If your belt has a round or square cross section, please give us the thickness as well. We can assist
you in choosing a belt usually 3-5% smaller than the length you measured.
....from the turntableneedles.com site
Jan 18, 2009 | Sony CASSETTE DECK Single Dual Cassette...
Brother MFC-240C Change Unable 50
I also had this problem, your solution was spot-on, remove the top cover and control panel and re-seat the encoded strip. simple.
boy, are you guys good.
Dec 11, 2007 | Brother Multi-Function Center MFC-240C...
Belt change
You will need a service manual for that model. Task not recommended for novice -- take to pro/tech
Dec 02, 2007 | Sony CASSETTE DECK Single Dual Cassette...
Source For Replacement Belts
http://www.studiosoundelectronics.com/cassette.htm
http://www.turntableneedles.com/index.asp
Oct 08, 2007 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
47 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Jonathon summesfield
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
