Question about Sony NWZB135F MP3 Player
Where will I get anew battery to replace the old one ?
My ceiling fan is about 9 years old and the remote is not working properly.
l reckon it might be time to update the fan or get anew remote, your choice...
Oct 17, 2017 | The Computers & Internet
Why won't my Mercury Grand Marquis's AC blow cold air? We asked them to replace the old Refrigerant, but instead they put in anew EATC, Alternator, Fan, and Battery.
faulty install take it back
system may have a leak .
O ring or pipe connection not tight enough
not enough gas added
was tx valve replaced or the newer inline variant of a tx valve
Jun 27, 2016 | 2003 Mercury Grand Marquis
Do i need anew battery
only after you have your altinator checked
Aug 21, 2014 | Cars & Trucks
Batteries don't charge anymore.where do I find anew battery pack, and how do I install it?
You will find the correct battery type at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To replace, start by removing the lotion packet cover on the back. Remove the screw on the back near the bottom to remove the pointed bottom of the shaver. Then remove the 4 screws to remove the battery compartment cover and access the batteries. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Mar 28, 2011 | Philips Philishave HQ7782 Electric Shaver
How do I replace the cmos battery?
There are several types. When you find it, it will be evident on the technique of replacing it. It is wither a round button cell or it is a cell with a small plug on it that plugs into the mother board. What makes yo think it is dead? Are you having to load the devices anew at each boot up ... and your clock is always wrong?
The battery allows the CMOS (aka BIOS) to retain the names and locations of various devices on your computer. But you probably already knew this stuff. In my experience, these battery's have very long life. I have laptops in my shop that are 10 years old and more whose batteries still function. Be sure what you are doing before you proceed.
Thanks for your question @ FixYa.com
Feb 10, 2011 | E-Machines Computers & Internet
1997,s10 won't charge ,put ault,in it anew cluster and will no charge the battery
REPLACE BATTERY CABLES IF OLD AS VECHICLE.CHECK FOR BROKEN BATTERY FEED WIRE OR VOLTAGE REGULATOR WIRES TO ALTERNATOR.CHECK FUSE LINK FROM STARTER TO ALTERNATOR SEE IF ALTERNATOR BATTERY FEED WIRE HAS POWER IF NOT FUSE LINK BLOWN..AND CHECK ALTERNATOR FUSE.
Dec 12, 2010 | Chevrolet Blazer Cars & Trucks
Old motor had 4 wires new motor has 7 wires new motor came with anew cap not sure how to wire
Are you trying to replace a two speed cooler motor? Verify the old motor is 120 or 240 volts which should be the same as the new one. Sounds like the new motor could be 240 volts.
Jun 29, 2010 | Heating & Cooling
Help! My top of the range coolskin shaver (bought May 07) has stopped holding its charge - any ideas?
Needs a new battery. Take out the old one and get the rating (volts and mah) mah =milli amp hours. Go online and get anew battery. Good as new!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 25, 2009 | Kitchen Appliances - Others
Low battery won't charge,change battery,now dead won't charge????
I had the same problem so I got a new battery & separate charger to charge both new & old, then replace as required.
Nov 05, 2017 | Uniden Cordless Phone exai398i
3month old battery does not charge full even after ten /more hrs.
i could charge to full by usv port in 16 hrs. now i do not let discharge more than 20% or chage every 10hrs.
ravi shanker malviya
Jan 18, 2009 | Sony Ericsson P990i Cellular Phone
Sony NWZB135F  MP3 Player Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
