Question about Canon P23-DHV Calculator
Printed numbers not same as input? I'm trying to simply add numbers, calculator is doing everything but add them and the numbers are not the ones I input.
How do I add or subtract numbers in polar form or rectengular form
If one or both numbers are in polar form, convert it/them to rectangular. Once both numbers are in rectangular form, simply add the two components separately: Add the two x components together, and add the two y components together.
If you're asking how to do this on a particular calculator, please specify the make and model.
Oct 15, 2013 | Office Equipment & Supplies
Where is the CPT key on the HPb11 Financial calculator?
There isn't one. Unlike calculators from other makers, the 17bII knows whether you've just input a number or not. Simply press the desired item without entering a number to calculate it.
For example, if the book says to press CPT then PMT to compute the payment, simply press the PMT key on the 17bII.
Sep 07, 2013 | HP 10bII Calculator
Cpt button
There isn't one. Unlike calculators from other makers, the 12C knows whether you've just input a number or not. Simply press the desired item without entering a number to calculate it.
For example, if the book says to press CPT then PMT to compute the payment, simply press the PMT key on the 12C.
Aug 30, 2013 | HP 12c Calculator
Cpt button
I need to reset the TAX percentage on my calculator
1. How to set "Tax Rate"
(1) If "Rate set" is printed above [%] key with your calculator,
1. Press [AC] and hold [%] for about two seconds.
2. Input Tax Rate and then [%].
* You can check Tax rate by pressing [AC] and then inputting [TAX+]
(2) If "Set" is printed above [%] key with your calculator,
2. Input [TAX+].
3. Input Tax Rate and then [%].
Oct 01, 2010 | Casio MS-80TV Scientific Calculator
We have several MS-170TV's I have misplaced the instructions. How do I re-calculate the Tax Rates at 15%? Terry
Q2
Please tell me how to do "TAX calculation".
A2 1. How to set "Tax Rate"
2. Input [TAX+].
2. How to calculate Price-plus-Tax and Price-less-Tax.
(1) How much is Price-plus-Tax of 100?
Press [AC], and input 100 [TAX+].
(2) How much is the Price-less-Tax of 105?
Press [AC], and input 105 [TAX-].
Oct 01, 2010 | Office Equipment & Supplies
How do I program the calculator tax+ Tax- buttons?
1. How to set/ change "Tax Rate"
2. Input [TAX+].
Press [AC], and input 100 and then press [TAX+].
Calculator will display 105 if tax rate is 5%
If you press [Tax+] again, it will show the tax amount..
Press [AC], and input 105 and the press [TAX-].
Calculator will display 100 if tax rate is 5%
If you press [Tax-] again, it will show the tax amount..
Jul 29, 2009 | Canon LS-100TS Calculator
How do I print a date format with sharp el 1801PIII?
To print the current date press once the Clock/Calendar key and then press once the Non Add/ Subtotal key (# key)
To print out any other date (or codes and other numbers that are not part of a calculation) just type it and then press the Non Add/ Subtotal key (# key). The date/number will be printed preceded by the # sign.
You may also want to download the SHARP EPL-1801PIII Operation Manual
Jun 04, 2009 | Sharp EL-1801P Calculator
When factoring or finding deriv. it gives me number?
oh yeah, you must've archived x, that is, you put a number onto the x variable so that the calculator calculates the answer for you, and THEN AUTOMATICALLY calculates the answer when x is in terms of that number. I am guessing you accidentally did 10[sto] x at one point. You can simply unarchived the x number and everything will be dandy!
Dec 08, 2007 | Texas Instruments TI-89 Calculator
Canon P23-DHV Calculator Logo
old marine
old marine
